09-03-2018, 01:50 AM | #1 |
<3 Flat Four
217
Rep 754
battery tender, prolonged storage
So i have the X5 in storage right now since i dont drive it much. Its been sitting for a little over a month and since the day it was parked, a battery tender was put onto the positive terminal in the engine bay. Started the car for the first time today and got the increased discharge warning which i thought was weird since i have a tender on. I then measured the 2 batteries in the trunk with a multimeter and found the main battery to be at around 13V(normal) but the auxiliary battery to be at 11V(low) only. This leads me to believe that the positive terminals in the engine bay cannot charge the aux battery at the same time as the main battery. Now I am stuck with a dilemma on maintaining both batteries. In order to charge the aux battery, i will need to directly connect a tender to it, which means
a) i will need to leave a gap in my trunk so the tender can be plugged in, which leaves the potential of bugs/dirt/dust/moisture getting into the interior and b) i will need to get 2 tenders plugged in at the same time, or move the tender between the 2 batteries every other week, or find a tender with 2 outputs at the same time Anyone have any suggestions?
2011 335is Le Mans Blue
2016 X5 xdrive 35i Alpine White |
09-04-2018, 12:21 AM | #2 |
Mmmmm…
1152
Rep 2,426
Drives: F15
That's the first time I've heard of that problem. I always just leave the tender up the front and I've never gotten increase discharge problem. Granted I've only left max three weeks.
2015 BMW X5 xDrive50i
BMW CCA 509766 Last edited by alphaod; 09-04-2018 at 09:29 PM.. Reason: *never* gotten |
09-04-2018, 12:58 AM | #3 |
590
Rep 1,267
I have the battery tender hooked up to the car using the connections under the bonnet for 3 months at a time, no issues at all, however I don't have the 2nd battery.
09-04-2018, 09:27 PM | #4 | |
4145
Rep 7,160
Drives: F90 M5 / F15 50i
'07 Yamaha R1 (sold)
09-04-2018, 10:22 PM | #5 | |
223
Rep 979
More then likely a bad battery...
2011 E92 M3 | JEREZ BLACK | EXTENDED BAMBOO NOVILLO | EXECUTIVE PKG | M-DRIVE | EDC | M-DCT
MODS | KW S/O | HRE P40SC | Akra Evo |ESS Akra Tune | ESS DCT tune | BMC drop in | StopTech Trophies | TMS Pulley | LUX V3 | BE Bearings and BE ARP rod bolts |
09-05-2018, 03:39 PM | #7 |
4145
Rep 7,160
Correct meant parallel lol. Damn my EE prof would be upset.
CatalinP589.50 |
09-05-2018, 09:38 PM | #8 |
<3 Flat Four
217
Rep 754
well im sure the batteries are wired up in parallel as its being charged by 1 alternator, but its the under hood positive terminal that is isolated(seems to be the case here) to the main battery as it is meant for boosting the car, which makes sense logically.
09-06-2018, 12:31 AM | #9 |
590
Rep 1,267
AFAIK, the 2nd battery is related to the Active Steering.
What battery and when it shall be charged is controlled by the electronic module on top of the main battery. As per BMW instructions for dealers having cars parked for a long time, the tender needs to be connected under the hood, nowhere alse. |
TOPEC216.50 |
09-06-2018, 09:48 PM | #10 |
<3 Flat Four
217
Rep 754
so i looked into the service manuals for anything related to charging the auxiliary battery. turns out u guys r partly correct. the aux battery is wired up in series to the main battery and its main function is to provide 24V of power solely (it seems like) for the purpose of "EPS/Electronic Power Steering". the manual also states to put a charger only on the positive terminal inside the engine bay, nth regarding the aux battery. makes me wonder how the aux battery gets charged.
ajob462.00 |
09-06-2018, 10:13 PM | #11 | |
4145
Rep 7,160
CatalinP589.50 |
09-09-2018, 01:01 PM | #13 |
508
Rep 648
Drives: 2016 F15, 2015 F83
Just to cover all the bases: Did you also ground the battery tender to the grounding post in the engine bay? Obviously, it won’t charge unless you did.
2016 F15 X5 50i M-Sport
2015 F83 M4 |
09-11-2018, 07:21 AM | #14 | |
458
Rep 570
I know it was said that there is a second battery for active steering, now I'm confused... I have active steering and, I'm pretty sure there is no second Battery at least not next to the main one? Am I missing something here? |
09-11-2018, 08:58 AM | #15 |
<3 Flat Four
217
Rep 754
in the service manual it states for vehicles that see higher axle load only, not totally sure on what that means. do u have any suspension options or just regular springs all around?
09-11-2018, 10:10 AM | #16 | ||
231
Rep 1,066
Drives: 2015 X5 50i M Sport
2019 Cayenne Turbo
Gone but not forgotten: 2006 2.0T A4 Avant, 2007 Z4 Roadster 3.0si, 2006 M Roadster, 2013 550i M Sport, 2015 Cayman S, 2015 X5 50i M Sport |
09-11-2018, 10:12 AM | #17 | ||
458
Rep 570
09-11-2018, 10:14 AM | #18 | |||
458
Rep 570
09-11-2018, 10:19 AM | #19 | |
458
Rep 570
Just trying to make sure they didn't squeeze a battery somewhere I don't know of, or wouldn't look at. The SCR ECU/Control Unit is for example located under the passenger side headlight, would have never know to search there since that unit is in the trunk in the 3 and 5 Series... |
09-11-2018, 11:04 PM | #20 | ||
<3 Flat Four
217
Rep 754
heres what it says
the more i look into this the weirder it gets Quote:
and if u search for "integral Active Steering", everything points to rear wheel steering, which to my knowledge, i "shouldnt" have, unless it was included inside some package that i wasnt aware of. infact, is this even an option for the F15 X5? never seen it mentioned anywhere
2016 X5 xdrive 35i Alpine White Last edited by TOPEC; 09-11-2018 at 11:29 PM.. |
09-15-2018, 09:04 AM | #21 | |||
458
Rep 570
09-15-2018, 09:19 AM | #22 |
Freude am Fahren.
835
Rep 1,287
Drives: F15 X5 xDrive35i
I don't have an Active Steering and have a second battery.
And according to ETK you get 2nd battery if you've got any of these options: S496A (heated rear seats), S536A (parking heater), S601A (TV), S6FHA (rear seat entertainment), S791A (fridge). I've got heated rear seats out of these.
Freude am Fahren.
MrTookies457.50 |
