08-30-2018, 10:32 PM | #1 |
261
Rep 769
Rotor resurface vs replacement
So my pads are coming to the end of its life and i am looking at rotor replacement or resurfacing. There is a shop around me that claims they can do it perfectly but im skeptical. I have to note that my rotors show a visible lip around the edge. Also, i am doing my first track day in October, i heard that resurfacing rotors and going to track is not the best idea.
While, i am replacing my rotors, is there anything i can preventitavely replace or upgrade like wheel hub or bushing? Thank you |
08-30-2018, 10:36 PM | #2 |
11586
Rep 12,726
You aren't supposed to machine these oem rotors. Some have without problems.
If I had to guess, it causes the drilled holes to become less chamfered and more prone to cracking. Still, probably not a huge deal unless you're tracking.
Instagram; @roastbeefmike
aswy6261.00 |
08-31-2018, 11:37 AM | #4 |
261
Rep 769
Do you think i should replace a anything else while i am at it? Or upgrade
08-31-2018, 11:38 AM | #5 | |
11586
Rep 12,726
08-31-2018, 12:44 PM | #6 | ||
261
Rep 769
08-31-2018, 12:59 PM | #7 |
11586
Rep 12,726
i'm partial to these, but they are expensive. probably the best as far as an oem replacement.
https://www.bimmerworld.com/PFC-Dire...ont-Right.html
08-31-2018, 01:33 PM | #8 | |
261
Rep 769
08-31-2018, 01:49 PM | #9 |
11586
Rep 12,726
nah, there isn't really anything big to upgrade in there. maybe stainless lines if you feel like flushing it?
08-31-2018, 01:53 PM | #10 |
721
Rep 3,964
I would replace the rotors. The price of the OEM Zimmerman rotors have come down quite a bit.
Here they are for less than $500 for the pair. https://www.ecstuning.com/b-zimmerma...34112283802kt/ Thats for the fronts. If the minimum thickness isn't exceeded the rears I think would be OK to turn. As 80% of the braking is done by the front. Dave
2020 Ford Mustang GT 6MT PP1 444rwhp
(Sold)2013 M3 Coupe-MR/BLK ZCP, 2011 M3 Coupe-MR/Blk 2007 Porsche 997C2S Speed Yellow/Blk sport seats 2004 BMW M3 Imola/Blk |
08-31-2018, 01:54 PM | #11 |
261
Rep 769
08-31-2018, 01:55 PM | #12 | |
261
Rep 769
08-31-2018, 02:46 PM | #13 |
178
Rep 591
i wouldn't take chance on resurfacing it esp if you're going to track it... we didn't buy these to expect cheap maint...
as someone said above, if you haven't already, consider stainless brake lines. change to castrol SRF, should be good to go for your 1st track day! |
08-31-2018, 03:42 PM | #14 |
721
Rep 3,964
Nice and life time warranty..however, thats for the rears. The fronts are $450.00
Dave
09-01-2018, 01:30 AM | #15 | |
261
Rep 769
09-01-2018, 05:35 AM | #16 |
336
Rep 724
One would have to measure the lows of the grooves on the rotor to get a good value. I suspect that 0.4 mm is not enough. Also let's say they can resurface at 0.2 mm over the minimum, will that lead to issues as the pad wears down the rotor? I'm not sure, but you are dealing with the fundamental safety system of the car. Also depending on your style and pads a weekend at the track may wear out your pads, then you would likely have to replace your rotors afterwards.
I would bite the bullet and get new rotors although one can often find low milage rotors in the classifieds. If there is no lip, you should be able to use as is. Otherwise the lifetime warranty from FCP would be hard to pass up (last set you would have to buy). |
09-01-2018, 08:09 AM | #17 |
1038
Rep 1,216
Bite the bullet and get new rotors or lightly used rotors. Search your local craigslist as I was able to find a full set of rotors with 5k miles on them for $450 from a totaled E92. Even with heavy use you'll get 40-50k miles out of the. So even buying new, $250/year in rotors if average out driving 10k miles per year. I spent that on my wife's A3 in 1.5yrs, so if you think about the cost vs what you get out of them it's much easier to digest the cost
2011.5 E90 M3
LeMans Blue |
09-01-2018, 11:31 AM | #18 | |
261
Rep 769
09-01-2018, 12:25 PM | #20 |
261
Rep 769
09-03-2018, 07:22 PM | #21 |
830
Rep 1,254
Agree w/ the others. Rotor resurfacing for most cars is a thing of the past. Just not worth it. @ ~ $600 for a new set, best to just bit the bullet and go new. Sucks but that's the game we play w/ these cars.
2009 E92 M3 build thread: https://www.m3post.com/forums/showthread.php?t=1754875
Follow me on IG - www.instagram.com/the_driven_enthusiast |
09-04-2018, 05:47 PM | #22 |
///M
237
Rep 703
Just buy them from FCP and have life time warranty. Bought all my brake stuff that I could from FCP euro on my recent brake job.
Follow me on IG: dre.pt
