08-27-2018, 01:19 PM | #1 |
489
Rep 426
Are these rotors done?
After I car washed, I let the car sit for a day. The next day I felt shaking when I was braking. investigating later I found this
08-27-2018, 01:48 PM | #2 |
84
Rep 71
Do a few fairly hard stops in a row to see if solid brake pressure machines the surface rust off the rotor, and if that eliminates the vibration. You'd be amazed how aggressively the brake pad manufacturers I've ridden with bed-in new pads, get going pretty fast and then threshold brake to haul it down to 15mph or so, then repeat several times till they're good and hot.
08-27-2018, 02:07 PM | #3 |
684
Rep 973
Drives: 2012 E92 M3 DCT ZCP
Looks like uneven pad material transfer, or the car sat when the brakes were super hot. They can be saved with some hard stops using semi-met pads or race pads per GRM Scott's comment above, or some sanding with garnet paper, etc. per this article:
http://www.stoptech.com/technical-su...nd-other-myths
2012 E92 M3 | ZCP | DCT | Space Grey Metallic | Black Novillo | BE/ARP | MPE V2 | AA green filter |BMW CF Rear Spoiler, RW Carbon Diffuser, CF Front Splitters | DTEC 160W Angel Eyes
08-27-2018, 02:19 PM | #4 |
Stop the hate, get a V8
3851
Rep 8,625
Now: 2017 Corvette Grand Sport, 2021 AMG C63 S sedan
Past: 2011.5 M3 sedan ZCP |
08-27-2018, 07:18 PM | #6 |
///M
160
Rep 190
So thats the result after having braked a few times during normal driving? Or is that just backing it down the driveway and they started shaking? Give us a little more info, or just try everything that was mentioned above and go from there.
08-27-2018, 09:48 PM | #7 |
Lord Scrip
1815
Rep 3,013
Drives: 2011 M3 Coupe
Not sure what the big deal is? A few stops and the rust build up will be gone. It may be an M3 but it's still just a car. Go to a dealership and you will see a lot of the cars like this. It comes from not driving.
Three Pedal Steve874.50 |
08-27-2018, 10:54 PM | #8 |
1688
Rep 3,140
Drives: 2014 M5 6MT
Part out?
2014 M5 6MT
08-27-2018, 11:18 PM | #9 |
489
Rep 426
I've done a good amount of hard stops 70-20 and it hasn't gone away and it's still shaking the car, I'm going to give it a week to see if anything happens. The car had 120k miles and probably still the original rotors so might be time to change them
08-27-2018, 11:22 PM | #11 |
1688
Rep 3,140
Drives: 2014 M5 6MT
Not your rusty rotors thats for sure.
2014 M5 6MT
08-27-2018, 11:25 PM | #12 |
489
Rep 426
08-28-2018, 06:01 AM | #14 |
5234
Rep 10,616
Those rotors look great. Barely any wear. You probably have not seen rust on your rotors before because you park inside and don’t drive in the rain. If you use your brakes, the surface rust will disappear. It will still be in the drilled holes and vanes but won’t affect anything other than looks. My drilled (actually probably cast) holes were rusted closed and my vanes choked with rust. I got another year by drilling out the rust and hammering the rotors to knock rust out if the vanes. I had huge lips on the outer circumference from wear — the pads did not sweep there.
08-28-2018, 10:25 AM | #15 |
4467
Rep 7,111
Like pbonsalb says, can't see much lips here? M3 discs are expensive mate, take wheels off investigate, clean calipers. Do some proper "bed in" breaking. Evaluate.
Good luck! |
08-28-2018, 10:53 PM | #17 |
///M
160
Rep 190
From the original post, it seems as if he drove the car, and some of the rotor surface rust came off, while some stayed on, and the braking wasn't normal, maybe pulsating?
If that's the case it would seem like the rotors are way out of whack, maybe I misunderstood the original issue. Anyway, I'll stop chiming in until the OP can clarify. |
08-28-2018, 11:49 PM | #18 | |
Lord Scrip
1815
Rep 3,013
08-29-2018, 05:53 AM | #19 |
5234
Rep 10,616
I seriously doubt the op warped the rotors. He simply needs to drive the car and use the brakes. Not treat it like a delicate work of art. If that does not remove the deposits, I’d borrow a set of race pads and then drive the car. Only as a last resort would I take the rotors to a machine shop. Those rotors look practically new to me.
08-29-2018, 10:13 AM | #20 | |
///M
160
Rep 190
Not sure if just any brake & tire shop would be able to do the same quality work as a vetted race shop, or are they all the same type of machines and/or processes of getting it done? |
08-29-2018, 12:42 PM | #21 |
60
Rep 129
I recently went through this a few weeks ago, scrubbing with race pads solved the issue for me.
After I completed the scrubbing I tossed on a new set of pads, brakes feel great, no issues at all. https://www.m3post.com/forums/showthread.php?t=1384226
Current : 2009 BMW E92 M3 SSII - Stage 2 - IPE F1 Exhaust
Previous : 2013 Audi A4 Moonlight Blue - Stage 3 (K04) E85 Last edited by Townending; 08-29-2018 at 12:50 PM.. |
08-29-2018, 08:00 PM | #22 |
Lord Scrip
1815
Rep 3,013
I really have no idea why everyone acts like the M3 is a spaceship engineered by NASA. Turning M3 rotors can be done at ANY auto shop. Rotors are rotors and anyone can put them in a turning machine....set the desired depth and walk away while the machine does it all. Cross drilled and/or slotted makes no difference.
tooloud10766.50 |
