08-08-2018, 01:40 PM | #1 |
137
Rep 316
oil level drop?
When I first got the car in 1/2018 with 53k mi, the oil had been changed and the oil level read near MAX. After another 4k mi and 7 months of very spirited driving, the oil level now reads middle of the range but still says OK. Is this normal? Is it just a sensor issue or am I leaking a little? Have not gotten the "Add 1 qt." warning yet. I really dislike this electronic dipstick crap. I plan on changing my oil at 60k and then following the 5k mi oil change rule from there.
EDIT: I realize this is common for n54/n55, but my car is a 128 and has the n51. Hoped oil consumption wouldn't be an issue with this motor. Vehicle doesn't smoke at all, but I am having a longer warm start (almost like it is struggling to crank for about half a second, only when hot outside), but that has happened since I've had it.
Commuter- F10 528i N20 8AT Jatoba Black
Show- F10 550i M sport 8AT Alpine White: Airrex Bags, 20" Forgestar F14s, Meisterschaft Catback Around town- E60 528i N52, 6AT, Monaco Blue Weekend - 1997 BMW Z3 M52, 5spd, Dunkelgrun: 230k mi, Intrax Springs on Bilsteins, Style 68s staggered AutoX/track - 2012 F30 N20, 6MT BSM Last edited by smeard; 08-08-2018 at 09:48 PM.. |
08-08-2018, 02:38 PM | #2 |
2459
Rep 3,585
This is an age-old subject, most cars don't go through much oil but it will be considered "typical" by a manufacturer to use up to a quart per 1000 miles. Aggressive driving would make that a touch more likely as well. Unless you know of an issue (i.e. smoky idle or acceleration) I'd probably just keep an eye on it.
08-08-2018, 02:46 PM | #3 |
13871
Rep 14,519
Drives: Audi S3....don't judge me
I just had to put a quart in 5000 miles after my last oil change. 2nd or 3rd time I've had to do that.
08-08-2018, 04:51 PM | #4 |
304
Rep 301
I have a 2013 that read oil level minimum after ~2000 miles, added a quart and it showed oil level max. Since its the first few months of ownership, I'll blame it on my spirited driving. The level is back in the middle now after another ~1000 miles.
Sounds like mine is dropping faster than yours... I don't see any oil under my car or smoke . I can live with a quart every few k. |
08-08-2018, 09:12 PM | #8 |
1543
Rep 3,071
I had an oil sensor go bad. Kept telling me I was middle, then low. I'd add some and then a while later it was middle or low.
Check for leaks on the lower engine tray. Look for leaks around the OFHG.
2011 135i w/ DCT | ZSP Sport Pkg | PPK | Ohlins R
08-08-2018, 09:41 PM | #9 |
36
Rep 142
08-08-2018, 09:45 PM | #10 | |
137
Rep 316
Show- F10 550i M sport 8AT Alpine White: Airrex Bags, 20" Forgestar F14s, Meisterschaft Catback Around town- E60 528i N52, 6AT, Monaco Blue Weekend - 1997 BMW Z3 M52, 5spd, Dunkelgrun: 230k mi, Intrax Springs on Bilsteins, Style 68s staggered AutoX/track - 2012 F30 N20, 6MT BSM |
08-08-2018, 09:46 PM | #11 |
137
Rep 316
Yes, although you have the turbo motor. Mine is the 128i, and I hoped oil consumption wouldn't be as much of an issue.
08-08-2018, 09:50 PM | #12 | |
137
Rep 316
08-08-2018, 09:51 PM | #13 |
137
Rep 316
I have heard OFGH being a common issue. Does it affect N51 too?
08-08-2018, 09:52 PM | #14 |
137
Rep 316
I don't have iDrive so no "green range" just a bar with min and max on it in my gauge cluster.
08-08-2018, 09:54 PM | #15 |
137
Rep 316
Will definitely check. Is it DIY? I would love to just take care of it myself
08-08-2018, 09:54 PM | #16 |
137
Rep 316
Will definitely check sensor. Wouldn't it say INACTIVE when checking the oil if it was bad? I know when my RDC got soaked it said TPMS was INACTIVE
08-08-2018, 10:30 PM | #17 |
137
Rep 316
heard it was an issue on n51/2 as well. mine is n51, getting it checked.
08-09-2018, 01:37 PM | #20 |
369
Rep 3,547
The difference between the min and max marks is 1 quart. So if you drop from the max to the mid, you are down a pint.
As has been stated, a pint in 4K miles is not unusual and no cause for alarm. My wife doesn't keep track of when I add for her but she needs a quart or two between oil changes in her n52. I change mine more often and never have to add. A pint in 4K miles is just a quart in 8K which is not bad.
128i Convertible, MT, Alpine White, Black Top, Taupe Leatherette, Walnut, Sport
Ordered 5/22/09, Completed 6/4/09, At Port 6/9/09, On the Georgia Highway 6/13/09, Ship Arrived Charleston 6/24/09 at 10pm, PCD 7/21/09 |
smeard137.00 |
08-09-2018, 02:31 PM | #21 | |
36
Rep 142
smeard137.00 |
