08-07-2018, 02:31 PM | #2 |
BimmerPost Supporting Vendor
8249
Rep 18,838
Drives: BMW
Good set of BMC filters with charcoal liners removed couldn't hurt. Otherwise, you're set.
08-07-2018, 04:27 PM | #3 |
1973
Rep 2,711
Below is a list of a proper Stage 2 setup in order of importance:
1. Tune 2. Down pipes 3. Charge pipes 4. 2-step colder spark plugs (NGK 97506) 5. Mid pipe or catless exhaust 6. Charcoal filter delete w/ either K&N or BMC air filters Most importantly, datalog as much as possible, so you can evaluate how things are going with the tune. Addition: Speaking from experience, try to go with Sunoco 260 GT Plus as an alternative to MS109. They're usually priced $30-$40 less with an octane rating difference of 104 versus 105. |
08-07-2018, 04:56 PM | #4 | |
Rep 9
I have 1,2,3 and 5 do you think that I should be good to try it out or no |
08-07-2018, 06:08 PM | #5 |
1973
Rep 2,711
08-08-2018, 12:31 AM | #6 |
717
Rep 1,184
08-08-2018, 07:26 AM | #7 |
261
Rep 573
Drives: 2008 E90 M3
I have run all types of fuel ... was not happy with the sunoco 260gt ... but the ms109 was great ... i only have intake cp and dp ... gaped down stock plugs to .020 and all is well so far
08-08-2018, 09:11 AM | #8 |
159
Rep 282
@swiftym3 I also tried the Sunoco 260gt plus and though it did feel a little bit more alive I wasn't really impressed. I am about to try the MS109 so what mixture did you use? 1/4 tank of 93oct and 5 gallons of MS109? also what difference did you feel vs the Sunoco. Thanks in advance for your imput
08-08-2018, 11:45 AM | #9 | |
1973
Rep 2,711
You are correct.
https://www.sunocoracefuels.com/fuel/260-gt https://www.sunocoracefuels.com/fuel/260-gt-plus Spark plug type and gapping all depends on how much boost you're pushing, and if you have any plans to regularly run full E85. For reference, I experienced a lot of breaking up at around 23-24 psi peak boost with NGK 97506s gapped to 0.020" on full E85. FYI .20 gap as you noted, would be way out of range. |
08-08-2018, 02:31 PM | #10 | ||
IG @bmwF9xG80
3813
Rep 7,593
What are you currently gapped at 0.018-0.019?
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 |
08-08-2018, 03:14 PM | #11 |
1973
Rep 2,711
I have a handful of theories based on months of logging, but don't want to go off topic. Every car reacts differently, even with relatively similar setups.
08-08-2018, 03:42 PM | #12 | |
IG @bmwF9xG80
3813
Rep 7,593
Op! You have to keep in mind adding 110oct to a 98-103 octane map for example won't do any good |
08-08-2018, 05:15 PM | #14 |
IG @bmwF9xG80
3813
Rep 7,593
With Bootmod3 Racegas Map they suggest VP MS109 or any 100+ octane equivalent. The folks in Europe are using 102+ RON from their pump as well.
08-09-2018, 09:03 AM | #15 | |
159
Rep 282
Thanks |
08-09-2018, 10:40 AM | #17 | |
1973
Rep 2,711
You can use just about any unleaded fuel without causing any damage to the engine components. Of course, high octane fuel without the proper tune will not make the car any faster. |
08-09-2018, 01:55 PM | #19 |
159
Rep 282
Thanks man that's what i wanted to know. which mixed would you say gave you the best results?
08-09-2018, 05:46 PM | #20 | |
1973
Rep 2,711
Read here for more info on race fuels: https://f80.bimmerpost.com/forums/sh....php?t=1249551 |
08-10-2018, 07:09 AM | #21 | |
261
Rep 573
Drives: 2008 E90 M3
