BMW M3 Forum (E90 E92)
European Auto Source (EAS)
      08-06-2018, 08:42 PM   #1
XCUSE_M3
Cruisin slow
143
Drives: Its a M3
Sway bar endlink
I have a issue with breaking my front BimmerWorld endlinks. This is the 3rd one. The threads just rip out. Has anyone had this issue before or what end link would you recommend. They are paired with MCS coil overs and hotchkis bar.
      08-07-2018, 11:18 AM   #2
nycplumber
686
Drives: slow
Are you too low for stock end links? I have a dinan sway bar and ohlins coilovers. I have been using the stock end links that I bought from FCP Euro and when they need replacement I just get them again for free.
      08-07-2018, 11:21 AM   #3
XCUSE_M3
Cruisin slow
143
Drives: Its a M3
Not sure I do neutral the bar with the adjustable ones and run the 11-12.5in endlinks. I might be just better off putting my stock back on.
      08-07-2018, 11:43 AM   #4
nycplumber
686
Drives: slow
I had to throw the Dinan end links out because they don't even work with their own sway bar, terrible company. Try the stock links and then if you ever have to replace them get them from FCP Euro so you don't have to pay again
      08-07-2018, 12:00 PM   #5
MSY
19
Drives: E92 m3
Turner makes a quality adjustable link however 12.5 is the stock end link length so i would use oem if i were you. Some dont have that option .
      08-07-2018, 12:15 PM   #6
slicer
slicer's Avatar
2739
Drives: 'E46 M3 Race Car, '23 X7
I use SPL links. Great company to work with. I had to get something unique to work with my Eibach bars and Ohlins TTX. I told them what I needed and they provided something custom to my spec.
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc.
INSTAGRAM - @Slicer_M
      08-07-2018, 12:50 PM   #7
MSY
19
Drives: E92 m3
Did you need shorter or longer links slicer
      08-07-2018, 01:00 PM   #8
XCUSE_M3
Cruisin slow
143
Drives: Its a M3
Based on how much I adjust it, looks like its around 11.5in the end link is not adjusted out very much.
      08-07-2018, 01:20 PM   #9
MSY
19
Drives: E92 m3
Ok than oem too long
      08-07-2018, 01:35 PM   #10
XCUSE_M3
Cruisin slow
143
Drives: Its a M3
It would work with no issues just not preform the way it should. Waiting for a response from bimmerworld.
      08-07-2018, 03:56 PM   #11
MSY
19
Drives: E92 m3
Well working mesns working without negative effect. If you can rotate the sway bar down and it fits than it will work fine. If its too long you wont be able to fit it. It doesnt matter what angle the sway bar lies
      08-07-2018, 09:10 PM   #12
admranger
Retired Curmudgeon
admranger's Avatar
Drives: ‘19 X3M40i, ‘18 m550i
With MCS you need to use the shorter Bimmerworld end links. They come in two different lengths.
'19 X3 M40 Carbon Black/Oyster, '23 Jeep Grand Cherokee L Summit, Past BMWs: '18 M550i, '18 330 GT, '16 X5 40e, '11 E90M3, '06 X5 4.4, '03 330i ZHP, '02 M3, '97 Z3 2.8, '95 M3 (2x), '94 530i (manual), '92 525i (manual), '88 M3, '87 325iS
XCUSE_M3142.50
      08-09-2018, 07:45 AM   #13
slicer
slicer's Avatar
2739
Significantly shorter, plus offset mounting hardware to access all of the sway bar settings. They can accommodate both short and long needs.
'23 X7
      08-11-2018, 01:30 PM   #14
wyatth
3549
Drives: E90 ZCP
Somewhat related .. is there any benefit from aftermarket end links if you’re at stock (ZCP) height?
      08-11-2018, 01:47 PM   #15
XCUSE_M3
Cruisin slow
143
Drives: Its a M3
Adjustable end links are for zeroing out the load on the sway bar when lowering so I would say you have no benefit.
      08-11-2018, 06:17 PM   #16
wyatth
3549
Drives: E90 ZCP
Thought so, thanks.
      08-16-2018, 05:29 AM   #17
nycplumber
686
Drives: slow
Wow those are nice! I might end up getting a pair because the OEM ones don't seem to last very long.
      08-25-2018, 11:57 AM   #18
tlrid3r
just another M3
tlrid3r's Avatar
Drives: e92 M3
The biggest issue is not making sure they don't bind on full lock steering on both side. Endlilnks have high axial load strength and really low radial load strength.
///M3... Don't want more power, Just want it to turn sharper one step closer each time. -Ohlins TTX Raceline, PolePostions seats, Akrapovic EVO, ARC-8, 1/2 Cage, Seat Delete, Stoptech BBK, solid Subframe and diff bushing, spherical bearing on everything.
m3post
