07-16-2018, 03:14 AM | #1 |
149
Rep 392
Drives: F13 M6
Haven't installed it yet. But I got this for $225 + shipping ($70).
Ill update later when its installed also, as thats gonna take me time do to schedule. It took about 5 weeks to be shipped from the Ukraine. |
07-16-2018, 04:38 PM | #3 |
493
Rep 1,003
Drives: 2008 E90 M3 DCT Silverstone II
Installed
This was mine installed last week...
Current: 08 E90 M3 DCT SSII w/ BE RB Swap, H8 Lux 180s, MS Drop-in AF, CF spoiler, CF diffuser, OEM CF leather trim, CF DCT paddles, Custom DCT flatbottom wheel, MirrorTap 9500ix, RockAuto rotors, Hawk HPS pads, AMS ECU 93 Oct Map Tune, GTS DCT update, Slambo custom undertray
07-16-2018, 05:09 PM | #5 |
1341
Rep 1,881
these refurb wheels are all e9x Msport wheels. they never use m3 cores. i learned this the hard way with my DCT, as they figured sending me a Msport paddle wheel would be the same thing....its not.
I am never able to post pictures on forums, all my pics are on IG @baye30 https://www.instagram.com/baye30/
Current Garage - [2011 E90 M3 ZCP] [2005 E53 X5 3.0 Sport] [1988 E30 325IS 24V] |
07-16-2018, 10:56 PM | #6 | |
149
Rep 392
Drives: F13 M6
It seems centered. I really like it man. My current wheel has significant wear on it. Also it is a reconditioned wheel (re wrapped). |
SDPLV493.00 |
07-16-2018, 10:57 PM | #7 | |
149
Rep 392
Drives: F13 M6
SDPLV493.00 |
07-16-2018, 10:58 PM | #8 |
149
Rep 392
Drives: F13 M6
This looks awesome man. How was the install and fitment? I am about to this this DIY:
It says to torque the center screw to 46 lb ft. Do you have any suggestions for me? |
07-16-2018, 11:21 PM | #9 |
493
Rep 1,003
Feels incredible. The heavier weight and it being a significantly better grip for anyone with bigger hands. I also have my servo stiffening at the highest level. I like my steering to feel like the Flintstone's car.
94jedi830.00 |
07-16-2018, 11:23 PM | #10 |
493
Rep 1,003
Yeah, the main difference is the wheel being noticeably heavier and thicker which is exactly what I wanted. I sold my OEM M wheel for under $200. I'm much happier with this.
07-16-2018, 11:23 PM | #11 | |
4452
Rep 4,014
07-16-2018, 11:24 PM | #12 | ||
493
Rep 1,003
07-16-2018, 11:26 PM | #13 | |
493
Rep 1,003
Mine had hole cut-outs, and I just swapped my paddles and wiring in.
07-16-2018, 11:30 PM | #14 | |
493
Rep 1,003
I didn't bother using my torque wrench (which defeats the purposing of owning one), just brute force and mental torque. It's a super easy swap. The toughest/most annoying part is the release pins on the airbags. When you put the airbag back in, make sure the wiring is out of the way otherwise it'll pinch and clip them and you'll be stuck soldering them back. Happened to me when I swapped my OEM paddles to extended carbon fiber paddles.
07-19-2018, 03:45 AM | #15 | ||||
149
Rep 392
Drives: F13 M6
Were you able to use the new harness in the new steering wheel as plug and play???? Just making sure there are no road blocks lol. I live in the City, but will going to a garage to do the swap. Rather not do this in my parking garage lol. |
jaimerod19.00 |
07-19-2018, 10:19 AM | #17 |
1341
Rep 1,881
The cut outs for the paddles are a different size on the M-sport wheel VS the DCT wheel. So there were gaps around the DCT paddle bases. even though i could not see it on the car, it bothered me.
07-19-2018, 10:26 AM | #18 | |
493
Rep 1,003
07-29-2018, 06:23 PM | #20 |
149
Rep 392
Drives: F13 M6
I just installed it and am posting pics. I have some close ups but will have to get you more later. The stitching is good. I can do a side by side later. Bc i have the OEM wheel also.
Iyzmi802.00 |
07-29-2018, 06:32 PM | #21 |
149
Rep 392
Drives: F13 M6
I just installed the wheel about an hour ago. I live in downtown Chicago and did it in my parking garage. The install went well, I used the DIY for the Nelson racing wheel and various other DIY's.
Same tools also. I used a breaker to break the steering wheel nut off with minimal effort. I then torqued the new on on to about 46lbs. The images are attached below. Please note that the blue stripe in the center is centered correctly, I just have the wheel rotated slightly. Its an optical illusion. I went on a test drive through parts of the city. I really enjoy this wheel, as my old one had significant wear. The grips fit my hands great and I feel very confident with the form fitting. The flat bottom takes a fl it of getting used to on turns, but I think its great. Its a good upgrade. |
