BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > M3 (E90 / E92 / E93) > Regional Forums > Canada
EXXEL Distributions
      05-28-2018, 12:43 PM   #1
cmyE93M3
cmyE93M3's Avatar
286
Drives: E93 M3
FMR (Footwell Module) Solution - Local
Hey,
So, this weekend I decided to install my new alcantara steering wheel, DCT boot along with the red start button. The steering wheel and DCT boot are from Coby who make awesome products btw
In doing so, I disconnected the negative terminal from my battery since I was messing around with removing the airbag and wheel etc...After the install, and reconnecting the negative terminal, I had the following errors:
Sorry for the length wise pics, wasn't thinking when I took them.
Anyways, what didn't work in the car:
  • Lights always on (safety mode)
  • DRL halo's not working
  • No power windows
  • No turn signals
  • Car would not go into drive unless the seatbelt was plugged in
A quick scan of the car and search resulted in the FMR module being either completely shot or potentially burnt out or software lost. I searched around for a local solution and came across SpeedoTronix located in Concord (close to Vaughan). I called Russ the owner on Saturday morning and he promptly returned my call, confirmed he also thought it was the FMR and he could fix it. Monday morning came, I drove up and 30 minutes later the car was 100% back to normal. He removed the FMR, fixed it and did so professionally. Highly recommend his services if anyone is like me and doesn't want to mess around with the electronics themselves or doesn't feel like giving BMW $1,200 for a new programmed FMR.
DM me if you want to know the price, I believe it's his normal rate but it was very reasonable in my opinion. Just thought I would share in case anyone has a similar failure in the car and could use a local shop who has done them frequently and clearly knows what he is doing!!
Speedotronix
www.speedotronix.com
Pic of Coby wheel, alcantara DCT boot and red start button from IND (handbrake I will install tonight in alcantara).
2008 E93 M3 | SSII | HRE P40's (Sold 2018)
2011 E90 M3 | Jerez Black (Sold 2019)
2019 Lexus IS300 (lasted 3 months)
2020 Toyota 4Runner TRD (fun truck)
2014 Tesla Model S P85 (wicked car)
2011.5 E92 M3 | Space Grey | ADV.1?s
Appreciate 2
inTgr8r2431.50
6ixSpd6015.50
      05-28-2018, 01:09 PM   #2
rcracin
1243
Drives: M3
Glad you got it sorted.
What did he do to fix it? Was an electronic part inside broken? Or a did a capacitor need to be discharged?
      05-28-2018, 02:35 PM   #3
cmyE93M3
cmyE93M3's Avatar
286
Drives: E93 M3
Some small electronic part and obviously reprogramming it, I didn't get into the details, once he started to remove it from the car and bench test and repair, it was all done in 10 minutes. The other 10 minutes he spent loading software and about 5 minutes to put it back in the car.
When I started researching on here I saw numerous posts of guys replacing the FRM with either new or used units that were flashed to their car. I much preferred keeping the original part but just getting it repaired if possible. If not, then I would buy new from BMW or BPM in the States or something. BMW here quoted me $729 for the part and 3 hours of programming at $164 per hour. SpeedoTronix did everything in 30 minutes and for $200 bucks including taking it out and putting it back in the car.
      05-28-2018, 11:04 PM   #4
triggz82
30
Drives: E90 M3
The FRM is insanely touchy on these cars. Mine fried when I had to jump start my car. Thankfully there are a few people that can bring them back to life. There is a guy up in Newmarket that can do it for around $100 if you want to remove it yourself (that in itself is a pain). My revived one ended up giving me more problems later with the keyless entry and I ended up replacing the whole unit.
      05-29-2018, 07:57 AM   #5
cmyE93M3
cmyE93M3's Avatar
286
Drives: E93 M3
Hopefully mine doesn't make a revisit for any issues, for now, it workings spot on. You should post who the guy in Newmarket is company wise if you were happy with there service in case someone north of city ever needs to get it reprogrammed
      06-04-2018, 12:34 PM   #6
drivetolive
88
Drives: Z4M Coupe
I want to thank you for posting this. I was experiencing electrical issues with my Mercedes C Class (in summary, the car wouldn't pass an etest because of a bad wire somewhere between the ECU and OBD port). After ripping my hair out trying to fix the issue and visiting several shops (including Mercedes), Russ at Speedotronix was able to quickly diagnose and quick the issue!
      06-04-2018, 01:20 PM   #7
cmyE93M3
cmyE93M3's Avatar
286
Drives: E93 M3
Awesome, I was impressed with him and his knowledge of how the systems work in the car, he could explain why it failed in detail, hence why I shared. Glad your prob got solved
      06-11-2018, 09:59 PM   #8
bb_00
18
Drives: 2011 M3
Glad to know there's someone knowledgeable with it locally. I had this exact same problem last year when I had my car's exhaust modded at a shop. Ended up the frying the FRM module and they had no idea how to fix it. Was quoted $700+ to get it replaced. I was pulling my hair out figuring out what to do while driving the car in that state for over 3 weeks and worrying that I might get pulled over for running the headlights on during daytime while never able to use the signal lights. Eventually sending the unit over to the States where a knowledgeable tuner helped me fixed it.
      06-11-2018, 11:24 PM   #9
BOOF-M3
BOOF-M3's Avatar
Drives: 2011 M3
The FRM's are under a special extended warranty under BMW. Mine blew at around 80k miles and the dealer replaced it for free.
      06-12-2018, 12:12 AM   #10
GORDON.M3
GORDON.M3's Avatar
1423
Drives: E92 M3 • F25 X3 M-Sport
Originally Posted by BOOF-M3 View Post
The FRM's are under a special extended warranty under BMW. Mine blew at around 80k miles and the dealer repacked it for free. I'm surprised no one else has posted here as to what the terms are under this warranty.
We don't have that in Canada, US warranties and recalls are completely different and most don't apply unless it was a major safety issue.
The only ones that we have for the M3 are the blower motor wire that catches fire and the Takata airbag.
INSTAGRAM: GORDON.M3
North American Mr12Volt Carplay/Android Auto Distributor
DINAN | EVOSPORT | VAC | ARP | RD SPORT | NEEZ | EIBACH | CSF | IND | BILSTEIN | KLASSEN | BREMBO | ENDLESS | BBS | BPM SPORT | PROJECT MU | EVENTURI
      08-17-2018, 10:09 AM   #11
nycplumber
686
Drives: slow
I'm pretty positive that my FRM is fried. Do you know the current extended warranty duration period?
Edit: sorry, that's a lazy question I called them and it's extended to 8 years and a 100,000 miles from in-service date.
Will update with more info
      08-17-2018, 10:47 AM   #12
BOOF-M3
BOOF-M3's Avatar
Drives: 2011 M3
I think someone mentioned 125k miles in this or another thread. I have heard others say that BMW replaces them regardless of mileage but I do not know fo sho. Good luck NYC.
FYI: You will loss any coding, tunes etc... when changing out the FRM. I hope you have files, cables etc... to reload them.
      08-17-2018, 10:50 AM   #13
Timujin
Timujin's Avatar
353
Drives: GMC Sierra
2010 BMW M3  [0.00]
What error do you have? I just had my FRM3 brought out of a coma Monday.
We grow food to feed the animals so we can eat the animals
      08-17-2018, 10:59 AM   #14
nycplumber
686
Drives: slow
I didn't get to run the codes yet. I will do that in about an hour.
      08-17-2018, 11:04 AM   #15
nycplumber
686
Drives: slow
That's good to know regarding the lost tunes and coding. I have a DCT/ECU tune but fortunately have both cables. Thanks for the info
I scheduled an appointment but the soonest loaner they will have is the 11th.
Does anyone know what causes this to happen?
      08-17-2018, 11:34 AM   #16
tom @ eas
BimmerPost Supporting Vendor
tom @ eas's Avatar
Drives: BMW
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
Correct. Snippet below:
BMW NA has extended the limited warranty for the Footwell module (FRM) on this vehicle to 8 years/125,000 miles as determined from the original in-service date. This component-specific limited warranty extension applies to defects in materials or workmanship. This coverage is subject to the same vehicle eligibility requirements, limitations, and exclusions that apply to the BMW New Vehicle Limited Warranty for Passenger Cars and Light Trucks. Please see SI B01 20 16 (DC 61 35 90 10 00).
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22
GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM
Appreciate 2
BOOF-M34451.50
      08-17-2018, 02:32 PM   #17
nycplumber
686
Drives: slow
Thanks guys I'm dropping the car off Monday and I'll report back with how the process was
      08-19-2018, 03:57 PM   #18
Yvette
761
Drives: M
I changed 5 times steering wheel and didnt bother remove the battery.
Timujin352.50
m3post
