05-20-2018, 08:50 PM | #1 |
Chief Warrant Officer
1025
Rep 1,638
235/40r18 Front Rubbing with stock suspension
So I recently put on a set of Apex EC-7's 18x8.5 front and 18x9.5 rear.
On said wheels I mounted MPS4S's in 235/40 front and 255/35 rear. These were the recommended tire sizes for a 135 with these wheels from Apex (actually they said 265 rear, but 255 would work). Anyway, I'm getting rubbing in the front when I hit moderate bumps. My car is still on stock suspension, so I was not expecting this rubbing. Could it be just a worn/sagging suspension that's causing it? My car is a 2012 with 80k miles, and I feel like my suspension may have gotten soft. Is it likely that it's just a soft suspension that needs replacing? I'm a little worried because I plan on upgrading my suspension soon and my concern is that any drop might exacerbate the rubbing (or maybe not, if it's firm enough compared to my current aging setup. Thoughts? Advice?
"Prius" is Latin for Eunuch.
"Hrothgar": 2012 135i: 6MT M-Sport, BSM/Blk; Nav, Premium, Convenience, HK Dinan Stage 2 +PPK /// BMW PE /// VRSF CP /// K&N /// Koni Sports /// RSFB Inserts /// MPS4S 225/255 /// Other Stuff |
05-21-2018, 03:58 AM | #2 |
232
Rep 2,643
Have a look at the tabs at the front of the fender panel where it joins to the bumper. That is normally the first place to get rubbing under compression. I believe its possible to grind then down a bit to gain more clearance. More negative front camber is likely to help as well.
Cavpilot2k1025.00 |
05-21-2018, 08:24 AM | #3 | |
1025
Rep 1,638
I'm pretty well versed on tuning and engine performance parts, but I am a relative novice when it comes to suspension and suspension modifications. Part of my planned upgrade is the M3 front control arms, which I understand add a small amount of negative camber, so I am hoping that helps without getting too aggressive on the camber for daily street driving (this is my DD, not a track car). My planned drop is pretty modest, as I am planning to use the BMW performance springs (from the now-unavailable BMW PS).
05-21-2018, 08:54 AM | #4 |
2416
Rep 3,550
What offset in the front, 45? That should do well, it's the size of my Arc-8's with 235 tires and I don't have any issues at all and I would say most people don't.
Blown struts would be a possibility, if they are indeed blown you will lose about 1/2" or so ride height because of the lack of gas charge, and also be a little more subject to bottoming out or getting close to it over bumps. |
Cavpilot2k1025.00 |
05-21-2018, 09:08 AM | #5 | |
1025
Rep 1,638
That said, lately I feel like it is softer and mushier that I recall it being "back in the day". Like I said, 80k miles and six years of hard street driving (on shitty New England pothole-laden roads) has probably taken its toll.
05-21-2018, 09:15 AM | #6 |
Loves me some MHD!
1858
Rep 1,719
No doubt at 80K they're essentially done.
That said it's pretty easy to tell if they're "blown"- two most common symptoms are the squish sound going over speed bumps indicating air in the damper, or fluid on the strut body and maybe other places depending on how bad it got. If you ever go over sandy places you can see oily sand stuck to the body also.
1and1
135i - E82.N54 2009 BSM - MHD / xHP / DCI, PR CP & 7.5" Race IC / N55 mid & Borla . . WL RSFI, Koni, Eibach & Dinan CP's, M3 CA's / EBC Red's & Firehawk 500's X1 - E84.N20 2013 MGM - JB4 - The Wife's, now with new turbo & ewg |
Cavpilot2k1025.00 |
05-21-2018, 09:45 AM | #7 | ||
4338
Rep 6,196
You need to add camber by moving the upper strut mounts further in, which means camber plates. |
05-21-2018, 11:26 AM | #8 | |
1025
Rep 1,638
I'll just have to see how it does once I get new shocks and springs.
05-21-2018, 11:44 AM | #9 | ||
4338
Rep 6,196
05-21-2018, 11:54 AM | #10 | |
1025
Rep 1,638
"235/40-18 and 265/35-18 tires will be a direct fit with no additional modifications required. These are actually our recommended sizes for the E82 on the 8.5/9.5 wheels." "No fitment issues and no additional modifications required with the 18x8.5" ET45 front and 18x9.5" ET58 rear wheels with the BMW Performance suspension and performance summer tires like the ones you mentioned." "No spacers or modifications would be required with the Bilstein spring/shock upgrades. It's not typically the ride height that causes clearance issues, but the width of the shock/collar setup with certain coilovers like KW, Öhlins, etc." Now to be clear, I am not blaming Apex for bad info (yet), because I suspect my suspension being worn and saggy as the actual culprit. MightyMouse: You're running 245 up front? what is your suspension setup? Because I'd rather go 145 too, when these need replacing, but I want to make sure they'll fit without a fender roll (with a lower aspect ratio - unfortunately MPS4S are only available with a 40 on the 235 width). Also I plan to put 265 rear when these 255's wear out. The 255 is pretty stretched right now.
05-21-2018, 12:06 PM | #11 |
61
Rep 138
https://support.apexraceparts.com/hc...-Fitment-Guide
I have the same setup except I have ARC-8 instead of EC-7. You shouldn't need camber plates with 235's. 245's is when you would need to start adding camber. My guess would be to check the struts first and go from there. |
Cavpilot2k1025.00 |
05-21-2018, 12:45 PM | #12 |
1025
Rep 1,638
So I just went out to my car and inspected it as best I could with it on the ground and wheels on. The right strut is definitely shot (maybe the left too, but not as bad).
There is no evidence of fluid on it (it could be long gone), but the easiest metric is this: On the left (good/better) side, I can slide my hand in between the top of the tire and the apex of the fender arc back to the rear meatier portion of my hand. On the right (bad) side, I can't get past my fingers. So clearly, there is significantly less clearance on the right where they should be the same. Inspection of the tire shows that the part that is rubbing isn't even the tread, but more like the shoulder half an inch or so outboard of the tread. And it is rubbing just inside the fender lip. It also looks like the upper part of the strut (the orange part, which I believe to be a boot, anyway), where it disappears up into the body, is more recessed than on the other side, suggesting greater compression to me. So, at least initially, it seems my problem is solved. I guess I need to accelerate my suspension upgrade timeline. Thanks, guys! Further input still appreciated.
05-21-2018, 01:10 PM | #13 | |
1025
Rep 1,638
Mr. Pharaoh60.50 |
05-22-2018, 06:52 AM | #14 | ||
4338
Rep 6,196
Cavpilot2k1025.00 1and11858.00 |
05-22-2018, 12:01 PM | #15 | |
61
Rep 138
Once I upgrade to MCS's, GC camber plates, and my current PS4S go bald, I will most likely go wider in the front and rear and be able to make a good comparison. |
