04-08-2018, 03:23 PM | #1 |
15
Rep 66
2nd oil cooler, how big do i want to go?
Last season, I had oil and coolant overheating issues at the track which leads me to thinking about adding a second oil cooler and then at some point, the csf rad.
Id like to put the second cooler at the opposite corner of the oem one, running lines out of the oil cooler housing. It seems like a 19 row cooler is a popular option, but what about going larger? Has anyone determined the largest size you would want to go while staying within the confines of the bumper? any other suggestions? this is almost entirely a track day car so there wont be any issues with cool oil daily driver stuff |
04-08-2018, 08:30 PM | #3 |
340
Rep 1,293
I ran a Setrab Series 6, 25 row oil cooler in the Evolution Racewerks housing. I had to cut the side mounting points off the core and build brackets to mount it at the top and bottom. I think this is the tallest, widest, and deepest oil cooler you can fit inside the bumper. It is extremely tight. Due to it's width and depth, the outer edge was about 1mm from the inside of the bumper cover. If you plan on hanging the cooler from the PPK aux radiator bracket, I wouldn't go any taller either or the 90* AN fittings required to run the oil lines will not fit within the lower engine tray.
04-09-2018, 07:17 AM | #4 | |
1207
Rep 2,028
04-09-2018, 08:34 PM | #5 | |
15
Rep 66
Why do the two need to be the same size? Would a single 25 row cooler be sufficient then? |
04-09-2018, 10:41 PM | #6 | |
1207
Rep 2,028
Either upgrade both coolers, run two stock size 10 row coolers, replace the stock 10 row with a 25row, or run the 25 row in series with the stock oil cooler. Last edited by bbnks2; 04-10-2018 at 07:51 AM.. |
04-10-2018, 12:07 AM | #7 |
California-bound
385
Rep 1,480
A Setrab 625, as stated above, fits with some *very* careful measuring and a bit of massaging. Just picked up a second 625 to run on the driver's side, will see how that goes.
Streets of Willow: 1:27.7 CW 11/15/15; 1:29.5 CCW 8/15/15 |||| Autoclub Speedway ROVAL (CCW): 1.52.6 - 12/2/17
Willow Springs - Big Willow (CW): 1:35.8 - 3/31/18 |||| Buttonwillow #13 (CW): 1:59.3 1/27/18 https://www.facebook.com/JakeStumphRacing |||| http://www.youtube.com/user/RaceMeMZ3 |
04-10-2018, 11:19 AM | #8 |
707
Rep 2,448
You ever finish the mounting bracket design for the passenger side cooler?
04-26-2018, 01:03 PM | #11 |
707
Rep 2,448
04-27-2018, 07:17 PM | #12 |
1Addict
3236
Rep 7,897
Would rather rip out the small stock cooler and stick a bigger one in that location.
04-30-2018, 10:03 AM | #13 |
187
Rep 670
Made the hoses and brackets. Using an Improved Racing external thermostat. I can see if I have any pics. I just made some simple brackets with plate steel. they are clamped behind the bumper.
2010 335i e90 Le Mans Blue/Chestnut Brown | M-Sport | 6MT
