03-18-2018, 09:01 PM | #1 |
///M Powered for Life
11490
Rep 10,329
DIY M Performance Steering Wheel (v2 electronic)
All
As the original DIYs are all gone because of Photobucket's decision to screw everyone people are having issues installing these steering wheels in M3s. The v2 electronic steering wheel was apparently not designed for the E9X M3, so the instructions you get from BMW are not completely accurate. The complication comes from where you're supposed to get power from under the driver's footwell This is how my 6MT steering wheel is wired. This works perfectly, every time. I've been using it for 3 years at the track without a hiccup. If you follow the BMW instructions and take these pics into account you should be able to get yours to work A1: green-brown -- gets plugged into a solid red cable on the harness A2: brown -- gets plugged into brown on the harness Here is the wiring harness you get with the cables with the A1 and A2 cables labelled Here's another photo of the same cables On the driver's side foot well you remove the cover with 3 torx screws and immediately run into this big connector Notice the wire taps |
03-19-2018, 12:51 PM | #2 |
168
Rep 405
Thanks for the updated pictures.
From all my reading the 'inconsistent shift lights' issue only exists on DCT-equipped models and to date there is no permanent solution so that it works consistently. I've had my V2 installed for about 4 months now. I'm drawing power from the JBE module underneath the passenger footwell. This solves the memory lost issue but every now and then I lose the shift lights. The only fix is to cut power to the wheel. Some owners solve this by installing a small SPDT switch to toggle power off/on to the wheel. Personally I don't need the functionality of the wheel when day to day driving so it rarely bothers me. When I get to the track I pull the ground terminal from the cars battery in the trunk for about 10s then reattach it and all is Ok. |
SYT_Shadow11490.00 |
03-20-2018, 06:49 PM | #4 |
2739
Rep 6,734
Drives: 'E46 M3 Race Car, '23 X7
Thanks for posting. Now I kind of want one.
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M |
03-21-2018, 01:55 PM | #6 |
63
Rep 189
Did you install or dealer installed it? How much for installation fee and did you tell the mechanic to wire it in a particular way?
2011 M3 E92 Alpine White/Fox Red DCT
03-21-2018, 02:48 PM | #7 | |
612
Rep 1,326
your wheel either doesn't retain memory of functions and shift lights work (at default setting), or retains memory and the shift light functionality is intermittent. i'm guessing the former.
2014 Frozen Black F10 M5 | Agency Power HFC Downpipes | Custom Open Flash Stage 2 Tune | KW HAS kit | 3D Design Lip | 3D Design Skirts | 3D Design Spoiler | IND Front & Rear Reflectors | IND M5 Badge | M Performance Steering Wheel | M Performance CF Shift Knob | Pedal Haus Pedals & Paddles | Turner Exhaust |
03-27-2018, 03:47 PM | #8 |
Rep 11
i have the dct version of this no issues with mine[/QUOTE]
I went to the dealer yesterday and was told that this part does not work with the DCT version. I don't understand why this car in Australia works but mine doesn't. I am ready to buy this today but my concern is that it won't work correctly. Here's the YouTube Video - |
03-27-2018, 04:42 PM | #9 | |
612
Rep 1,326
2 ways to wire it: 1) via 12v ashtray: wheel won't retain memory of functions and but shift lights work and reset to default setting every start 2) via JBE power: retain memory of functions and the shift light functionality is intermittent (can install a power on/off switch, what I have done to get shift light functionality)
03-28-2018, 09:14 AM | #10 | |
Rep 11
-Vikas Last edited by VikAry; 03-28-2018 at 09:20 AM.. |
03-29-2018, 11:12 AM | #11 | |
612
Rep 1,326
03-30-2018, 09:55 AM | #12 | |
Rep 11
Thanks again. |
08-09-2018, 02:03 PM | #14 |
1038
Rep 1,216
Bumping this up. I just had my V2 installed. The only time the shift lights work now is when Im in the setting screen for it. When I first picked it up fro BMW, it worked after saving the setting. Im assuming my issue is whats discussed here in the thread. So, what should I tell the BMW tech to do exactly?
2011.5 E90 M3
LeMans Blue |
M3 Number 863221.00 |
08-09-2018, 02:04 PM | #15 |
11490
Rep 10,329
Update: my wheel was connected as described above and it works perfectly, just like the 6MT one.
It doesn't lose memory, etc |
08-09-2018, 02:06 PM | #16 | |
11490
Rep 10,329
I do have to turn mine on to do anything with the two thumb buttons |
08-09-2018, 02:20 PM | #17 |
1038
Rep 1,216
Yup, mine as well. Every time I start the car it lights up and says M Performance but then I have to hold the buttons to turn it on. If I go to the setting screen for shift lights, they will light up at any RPM. The minute I hold the left button to save, they go away.
2011.5 E90 M3
LeMans Blue |
10-04-2018, 03:32 PM | #19 |
Lt Col. …who can’t wait for his next track day!
32
Rep 227
In for more info!
SF
•SOLD - '08 M5 Sepang Bronze/Full Merino leather/ Exec Pkg/HUD/SMG/H&R/DINAN/Coded
•'12 E92 M3 Space Grey/M-DCT/ZCP/ZPP/DINAN/ACM Test Pipes/BPM StageII Tune & Coding/M Perf Exhaust, Race seats, Alcantra V2 steering wheel, gloss grills/ModeCarbon GTS wing/GTS DCT Tune, CF int trim, door sills/LUX H8 V3/CSF race oil cooler/Trackspec hood vents/GT4 Rep CF splitter & rotor ducting/Hawk DTC60/KW CS 2way NR/B'world/Hotchkis/Eibach/Apex |
10-04-2018, 03:35 PM | #20 | |
11490
Rep 10,329
Sometimes i think mine don't work but because they're set to flash at 8500. So i have to go way up before they start turning on |
10-04-2018, 10:17 PM | #21 | ||
1038
Rep 1,216
2011.5 E90 M3
LeMans Blue |
