03-11-2018, 06:55 AM | #1 |
#topdownS65
67
Rep 133
E93 - stiffening front end
I have noticed the lack of rigidity in the front end and overall chassis in the E93, for the obvious reason - the convertible. My local shop has recommended a front sway bar. They're a Dinan dealer, and installed a Dinan FSB on a customer's E93 M3, they said the customer is very happy with it. Is this the best option? Any other suggestions?
Thank you! |
03-11-2018, 07:28 AM | #2 |
2432
Rep 11,667
I don't know much about the e93 front chassis, but if chassis rigidity is the issue.
Changing the sway bar will do absolutely nothing to change that. To take flex out of any chassis, structural reinforment is required.
'21 M2C Hockenheim Silver
'18 718 Cayman S Lava Orange (sold) '13 E92 M3 Santorini Blue (sold) '07 Z4 M Coupe Alpine White (sold) |
03-11-2018, 07:50 AM | #4 |
11586
Rep 12,728
No. There is little you can do to actually strengthen it without spending a lot of money.
A sway bar may give you the illusion of being stiffer, but it is suspension tuning. What is your goal with the car?
Instagram; @roastbeefmike
03-11-2018, 08:05 AM | #5 |
#topdownS65
67
Rep 133
The goal is to not have the front end be as wobbly as a limp d*** (over exaggerating here - it still handles well, it would be nice to be more planted)
When I go over any uneven road surface the front end flexes. I've driven early 2000 mustang verts that are stiffer than this. I was driving in the backcountry and encountered a dirt road with those terrible rut strips, the car was flexing so much I thought the windshield was going to crack. |
03-12-2018, 04:06 AM | #6 |
11586
Rep 12,728
might sound stupid, but lets ask anyways- have you checked the swaybar links to make sure they aren't broken off? how about under the hood- are the strut braces to the firewall still present and tight?
03-12-2018, 07:40 AM | #7 |
5234
Rep 10,616
I’d check the suspension bushings and shocks as well to make sure the stock parts are doing what they should be doing. Convertibles in general are lower performance cars, because of the added weight and decreased rigidity, but presumably the OP knew that when he bought one and was more interested in top down cruising than performance.
ebisu81079.50 |
03-12-2018, 09:46 AM | #8 | |
#topdownS65
67
Rep 133
03-12-2018, 09:58 AM | #9 | |
748
Rep 1,256
Drives: '08 M3, '09 328xi Sport Wagon
Sounds like you have a serious issue.
SYT_Shadow11490.00 |
03-12-2018, 10:57 AM | #10 |
5234
Rep 10,616
I have driven only one E93M3 and had no complaints, but I was not on a track with it. I thought the straightline performance was a little dull compared to my modded sedan, but noticed no bad handling issues.
