03-10-2018, 11:05 PM | #1 |
81
Rep 122
Drives: 08 135i AT
ARC 8's and big tires
Just got my new wheels and tires on!!
Arc 8 18x8.5 front et38 and 18x9.5 rear et58 RE71r tires 245x40 front 275x35 rear TC Kline s/a coil overs -3.2 front -2.2 rear Very little rubbing at this height, but i had to remove a couple spots on the front fender liners and heat the filler tube for the tank and push a small dent into it in the rear
08 135i AT / xHP stage 3 trans flash / vrsf 7.5 hd FMIC/ docrace single 6266 dbb precision turbo kit / TCKline s/a coilovers / RB external pcv kit / Active Autowerke ChargePipe / Wavtrac lsd / Whiteline subframe and Diff Full bushings / WedgeTuning full e85 custom tune 26psi / Blackmarketparts Port Injection Kit
03-12-2018, 06:56 PM | #2 |
C2H5OH
3915
Rep 2,144
If you had to heat the fuel filler, I'm afraid you're going to run into issues after a few laps. Tires flex and what clearance you think you made probably wasn't enough.
Just keep a real close eye on it. |
Thewind72780.50 |
03-12-2018, 07:43 PM | #3 |
121
Rep 2,037
Drives: 2008 135 blk, blk, step
Garage List 1994 Porsche 968 Cab [0.00]
2017 AMG GTS [0.00] 1994 Porsche 968 Coupe [0.00] 1977 Mercedes 450SE ... [0.00] 2008 135 [8.00] |
That's a serious car TheWind, same for ImIn. You need some better seats and a 4 point harness system next with all that power and traction. No antiroll bar mods? I didn't change mine either.
Injen, RR OCC, MadDad Whisper, donut spare, 19x8.5et43fr 19x9.5et45r Volk LE37's, rear fenders rolled/pulled, PSS4S 225/35fr 255/30r, KW V1's, AR coated catless dps, Cross strutbar, CF grills and license plate holder, iCarbon diffuser, ETS black anodized FMIC, M3 control arms, Quaife, ER chargepipe, ForgeDV's, Topspeed Custom Tune, V3sims, Braille, Andrey_GTA rear hub mod, Ebay Mstyle front bumper and performance style side skirts.
Thewind72780.50 |
03-13-2018, 05:38 PM | #4 |
81
Rep 122
Drives: 08 135i AT
it was just barely touching the inner fender liner at the filler tube and i pressed it in about a half inch so should be good but i'll keep a close eye on it for sure.
03-13-2018, 05:41 PM | #5 | |
81
Rep 122
Drives: 08 135i AT
really don't see any need for a cage at this point the local spot i run at is pretty small top speeds of around 80 on the straight. seats on the other hand..... Those are next!!
03-15-2018, 12:04 AM | #6 |
128
Rep 301
car looks great, nice setup!
Thewind72780.50 |
03-15-2018, 09:05 AM | #7 |
81
Rep 122
Drives: 08 135i AT
Thanks!! this weekend we see how she handles. ill post a vid as soon as i can
03-21-2018, 06:05 PM | #8 |
3530
Rep 6,752
Looks incredible with that meaty tire setup. Well done
925-245-0773 /// info@apexraceparts.com
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers |
Thewind72780.50 |
03-22-2018, 10:37 AM | #9 |
81
Rep 122
Drives: 08 135i AT
Here's my fast lap from the time attack.if you listen close at the end you can hear Harry's give a 35.8 second time. Their timer picked it up at 35.99. pretty happy with the way she performed, sway bars and R888r's are on the way for the next event and we'll see if i can scrub off a couple 10th's Me and my friend were within hundredths of each others times so at least i know the car is consistent
BimmerAg425.00 |
03-22-2018, 05:25 PM | #10 |
425
Rep 545
Nice driving! I just noticed your 2018 tech inspection sticker haha. Do you run with Spokes?
2011 BMW 135i ///M-Sport, DCT
Bilstein B12 kit, Dinan camber plates, M3 front control arms, Whiteline poly RSFB, MHD Stage 1, cp-e Charge Pipe, H&R Front sway bar, BMW performance diffuser |
Thewind72780.50 |
03-22-2018, 11:02 PM | #11 |
81
Rep 122
Drives: 08 135i AT
Thanks man, I'm still learning for sure. I ran the first event and will probably do the next austin event but its to hard for me to get to SA that damn early haha
BimmerAg425.00 |
03-23-2018, 08:19 AM | #12 |
425
Rep 545
Yeah, I've been meaning to make it up to one of the events at COTA, but it's hard to get up that early for me too haha.
Thewind72780.50 |
