      03-04-2018, 07:46 PM   #1
mack128i
1er
10
Drives: 2013 128i e82
OEM ET and Oversized Tires for 2013 128i e82
Hey all,
Very new to car mods, and are wanting to put 18s on my 128i. I have just learned about offset and want to ensure that the offset for the custom wheels will not be anymore than the OEM ET.
Additionally, I am seeing that 255/35/18 should provide a squared fit for the set up, not wanting to run any camber, just a square fit with no rubbing, or at least minimal on any hard bumps etc.
Wanting to run wider on the rear than front, maybe 235 and 255?
Any insight on the OEM ET and max size for oversized tires are appreciated. Again, keep in mind I am a newb, have done some research, but would rather hear first hand from other 1ers. Again, keep in mind in your response I have no ambition on moding the suspension or have any spacers.
      03-05-2018, 12:05 PM   #2
Gangplank
Gangplank's Avatar
Drives: 2011 e82 135i n55 Sport w/ DCT
2011 135i  [0.00]
Best suggestion I have is to search and review the threads.
2011 135i w/ DCT | ZSP Sport Pkg | PPK | Ohlins R
      03-05-2018, 02:45 PM   #3
one 35i
one 35i's Avatar
Drives: CSM/terra
wheels/tires
This: http://www.originalwheels.com/bmw-wh...8i2013rims.php
You will get an idea of oem rims that might interest you plus you get the size and offset.
Also this will help with accepted tire size for rim(doesn't take suspension variances into account.)
      03-06-2018, 06:11 PM   #4
mack128i
1er
10
one35i,
Thanks for the response, however I am mounting custom wheels, not OEM. In the meantime, I have found the OEM offset to be 47 for my wheels. Any idea how much a variance there can be without having any future repair issues?
      03-07-2018, 09:03 AM   #5
BimmerAg
BimmerAg's Avatar
Drives: 2011 135i
For stock suspension you can be fairly aggressive with your wheel offset choices. It really depends on the tire size you choose though. If you want to run 235/255 staggered, then a 35-45 front offset and a 40-50 rear offset should work. Of course, this also depends on wheel width as well, so it's hard for anyone to tell you what offset you need if we don't know what wheel widths and tire sizes you want to use.
2011 BMW 135i ///M-Sport, DCT
Bilstein B12 kit, Dinan camber plates, M3 front control arms, Whiteline poly RSFB, MHD Stage 1, cp-e Charge Pipe, H&R Front sway bar, BMW performance diffuser
      03-07-2018, 09:10 PM   #6
mack128i
1er
10
BimmerAg thank you for the insight...wanting to run these wheels...the offset is 38
https://www.carid.com/rtx-wheels/env...458893610.html
And these tires
225/40 F
255/40 R
https://www.carid.com/continental-ti...-84033809.html
Could I run a larger ratio in the rear? Like 45-50? I would like to have it as close a safely possible to both the front and rear wells...
      03-08-2018, 08:25 AM   #7
BimmerAg
BimmerAg's Avatar
Drives: 2011 135i
Those wheels should be alright with the tire sizes you mentioned. Note that the hub bore diameter is 74.1mm for the 18" wheels, so you'll need an adapter ring for them to fit our 72.6mm hub. I'd be careful about trying to run higher aspect ratio in the rear for two reasons: One, if the front/rear tire diameters are too different, it could affect the function of ABS, DTC, etc... Two, there have been some people that have experienced tire rubbing on the inside part of the passenger wheel well where the fuel filler neck is. I've seen a picture of someone who rubbed completely through the filler neck and had to fill up with a hose and funnel! A taller tire, will make this situation even more likely.
      03-09-2018, 02:23 PM   #8
mack128i
1er
10
BimmerAg so...the search continues...did not realize tryna find wheels would be so technical. I don't have a wheel shop in my area, so makes the interweb purchases very nerve wracking...
But if I do go with the set that I posted here, I would have to find somewhere to get the adapter ring...
Have settled on 225 (maybe 235)/40/28 on the front and 255/35/18 on the rear, just got to find a wheel with a 42ENT...
      03-09-2018, 03:06 PM   #9
BimmerAg
BimmerAg's Avatar
Drives: 2011 135i
Adapter rings:
Aluminum: https://www.ecstuning.com/b-ecs-part...hoC0sYQAvD_BwE
Plastic: https://www.ecstuning.com/b-ecs-part...BoCqQEQAvD_BwE
      03-18-2018, 07:35 PM   #10
mack128i
1er
10
BimmerAg thank you sir!
