02-26-2018, 02:50 PM | #1 |
121
Rep 423
Engine warmup - oil temp drops when driving
I am trying to figure out if my cooling system runs properly. When I start the car in approximatey 8C and start driving it heats up much faster when I get stuck in traffic early rather than when actually driving. For example, when I start off into traffic and mostly stop and go, the car hits 100C after 10-15 min. After I get out of traffic it instantly drops to a little over 75.
When I start off in the evening and drive in very little traffic, it takes much longer to reach 100C. Is this normal or should I check my thermostat? All my other cars built up temperature rather constantly, with no drops.
02-26-2018, 03:29 PM | #2 |
2383
Rep 3,730
Drives: 2018 M2
check your belly pan condition. only time my oil temp dropped a bit while driving was in winter after my belly pan was ripped off. without it the oil cooler gets a ton of cool air and cools off quicker
02-26-2018, 03:53 PM | #3 |
403
Rep 1,171
seems normal from my experience. The M3 oil temp does fluctuate and reflect precise temp, it's not like a Toyota where it just stays at the middle line all the time even though the real temp maybe be fluctuating a little bit.
02-26-2018, 07:10 PM | #4 |
121
Rep 423
msan I know, but it's sometimes a ~20 degrees drop after I move off from stop and go traffic. Are the fluctuactions you mentioned that big?
EJT86 Thanks for the info, I will check it. What should I look for exactly? My underbody was checked recently as I have cracked the left panel (the small one) and the workshop did not report anything wrong with the belly pan. Does the oil cooler have any type of thermostat? |
02-26-2018, 08:10 PM | #5 | |
2383
Rep 3,730
Drives: 2018 M2
02-27-2018, 02:54 AM | #7 |
4470
Rep 7,114
Certainly goes up in stop and go traffic while down at high way. 20degC however is much more than mine fluctuate, more like 90-100C. In my experience the temp meter is pretty accurate but you may double check with for instance Carly to make sure it works properly.
02-27-2018, 04:13 AM | #8 |
11586
Rep 12,728
your car is behaving normally. nothing to be alarmed about.
there is a little bit of misinformation in here. the front felt undertray helps with cooling. having a missing undertray will actually cause the car to run warmer than normal. this is because instead of air being forced through the oil cooler and out the bottom of the undertray, the air simply flows around the cooler (less resistance) and out under the car. this makes the cooler less efficient. the reason op's car heats up faster in traffic is simple, there is less airflow forcing air through the cooler. if you look at the felt undertray from the side, you will see it is shaped like an airfoil. this causes a low pressure zone behind the oil cooler outlet, which encourages airflow through the cooler. there is also a shroud behind the cooler guiding the air out of the exit. if you start the car and it is not up to full temperature once you get to a clear highway and get up to speed, it is going to take longer because the cooler is simply working at it's most efficient level.
Instagram; @roastbeefmike
02-27-2018, 07:23 AM | #9 | |
2383
Rep 3,730
Drives: 2018 M2
02-27-2018, 10:35 AM | #10 |
13
Rep 75
Mine behaves the same as OP, But I do believe this is normal behavior for a engine with an oil cooler. I live up in Vancouver, WA... where this time of year the avg. weather temp is mid 40*F. In the morning on the way to work, it will warm up 5-10* while sitting at a red light, then stay the same until I come to a stop again and there is no airflow through the cooler, thus allowing the temperature to rise. On the highway this time of year, the oil temp will sit right around 175-180*F cruising in 6th @ roughly 65 MPH. If you are truly worried about oil getting to operating temp faster if you do a lot of highway on your commute or driving, you can always cut yourself out a piece of cardboard the size of the cooler during the winter, and zip tie it to the front. Blocking ambient airflow.
-GARAGE LIST- 1: 2008 Interlagos Blue E92 M3 6MT 2: 400 WHP Turbo M52 E36 (Drift car) |
02-27-2018, 12:48 PM | #11 |
121
Rep 423
Thanks for the input everyone, it seems I am not used to a car with an oil cooler yet - it's my first winter with the M3. I was just worried that there is something wrong with my thermostat.
02-27-2018, 01:02 PM | #12 |
Stop the hate, get a V8
3851
Rep 8,625
Also, these are not air-cooled cars.
Now: 2017 Corvette Grand Sport, 2021 AMG C63 S sedan
Past: 2011.5 M3 sedan ZCP |
02-27-2018, 01:16 PM | #13 | |
13
Rep 75
I've also read that there is a OIL thermostat in the filter housing, not sure if that's true or not... Because if there was, the oil would warm up gradually at a steady rate, then stay consistent, similar to the water cooling system...Not exponentially like it currently does. Can anyone clarify this and debunk?
02-27-2018, 01:29 PM | #14 | |
403
Rep 1,171
See my post here http://www.m3post.com/forums/showpos...7&postcount=81 |
02-27-2018, 02:29 PM | #15 | |
13
Rep 75
