02-25-2018, 11:33 PM | #1 |
8
Rep 47
Help Needed!!! Rear brakes overheating on track
So I have an e92 m3 with stoptech ST-40's up front only. Over the course of 4 track days, I noticed that my stock rears were eating up pads way faster than the fronts and then we realized that my rear rotors were as, if not more, blue than the fronts.
Fast forward to yesterday, and the guys at JPSS (highly recommend if anyone needs any work done in the carolina/virginia area) met me in the pits at VIR after a couple of hot laps. After 1 warm up and 3 hot laps on the full course, they shot my rotors.....464/450 degrees in the front and 566/537 FOR THE REARS! Temperature stickers on the rear calipers show max temps below 400, but not clue how the rear rotors are getting so hot! Any ideas what is causing this and if I should be concerned? I am running PFC 08's on both front and rear. Most days are run at VIR and I haven't experiences any significant brake issues (fade, rear-end hoping out, nothing). |
02-26-2018, 07:07 AM | #3 |
11586
Rep 12,728
DSC uses the front brakes around 95% of the time. It's not that.
Something is mechanically wrong with your rear brakes. Dust boots are probably ripped to shit and the pistons are somewhat sticking.
Instagram; @roastbeefmike
02-26-2018, 01:24 PM | #5 |
8
Rep 47
No nannies regardles.
My thoughts exactly but there seems to be no visable issues with the rear brakes minus the pad wear. Car seems to respond as intended which would make me thing that they aren't sticking and/or dragging.....Just say screw it and put rear ST40's on? |
02-26-2018, 02:52 PM | #6 |
36
Rep 63
DSC uses the rear brakes for stability and understeer control. If you have it off, then you have a mechanical problem.
MilehighM3915.00 DrFerry6728.50 |
02-26-2018, 04:00 PM | #9 |
403
Rep 1,171
I see you have a thread about the DCT malfunctioning also. Maybe the rear brakes and DCT problems are related in some way. Just a thought.
02-26-2018, 08:24 PM | #10 | |
11586
Rep 12,728
he used AIM data to see when brakes (and which brakes) are being applied when he is not pressing the brake pedal.
peter de la mare126.00 |
02-27-2018, 07:55 AM | #11 |
11586
Rep 12,728
I have to clarify something, when I said DSC, I meant MDM.
I don't know exactly how DSC works, but if you're tracking with DSC on, you're going to be slow as hell because it is too intrusive for even cool down laps. My apologies.
02-27-2018, 11:23 AM | #12 |
36
Rep 63
03-01-2018, 07:09 PM | #13 |
8
Rep 47
Yeah the system is completely off (Holding the DSC button until it turns yellow and I get teh DSC off message). In the beginning I ran with the MDM mode on, but that was long ago and have been running in this off manner only.
I have a vbox system that came in today, I am going to Atlanta this weekend and will pull wheel speed data to see if I can see anything being effected. |
03-03-2018, 09:02 AM | #15 |
2164
Rep 5,548
You’re running a ST40 F brake kit with rotors that have better cooling, as well as more thermal mass, than stock rotors. I’m not surprised your R stock rotors are running hotter than the ST40 F rotors when using the same brake pad compound F and R. The pins in the stock rotors do a good job of blocking air flow to the rotor vanes whereas the ST40 floating rotors have no vane obstruction.
Does the stock brake bias change when running the ST40 F kit with stock R brakes? |
03-03-2018, 06:32 PM | #17 | |
5234
Rep 10,616
03-04-2018, 07:48 PM | #18 |
Retired Curmudgeon
2985
Rep 4,047
Two things I would like to know: When and where are the brake temps being taken and how are they taken?
Also, take the temps after driving your car to the track and brake into your parking spot. What is the difference in temps when you do that?
'19 X3 M40 Carbon Black/Oyster, '23 Jeep Grand Cherokee L Summit, Past BMWs: '18 M550i, '18 330 GT, '16 X5 40e, '11 E90M3, '06 X5 4.4, '03 330i ZHP, '02 M3, '97 Z3 2.8, '95 M3 (2x), '94 530i (manual), '92 525i (manual), '88 M3, '87 325iS |
03-06-2018, 02:06 PM | #19 | |
567
Rep 801
2011.75 E90 M3 | 2006 GMC Sierra LBZ | 2004 X5 3.0i 6MT | 1995 M3 S50B32 | 1990 325is | 1989 M3 S54B32
Hers: 1996 911 Turbo | 1989 325iX |
03-06-2018, 03:28 PM | #20 |
1478
Rep 2,672
I'm curious what tires you are running?
I run ST-40 fronts and stock rears and used to run PFC-08's all around. I found that I was boiling my fluid up front with this setup. I now run Castrol SRF, Pagid RS-29 fronts, RS-19 OE shaped rears, and then throw 1mm Ti shims in the front after the first track weekend (they won't fit when pads are new). No issues at all with Cup 2's and RE-71r's though I suspect I will need to upgrade my brake system when I switch to slicks. My theory on the PFC-08's is that they run hotter and transmit more temperature into the calipers than the Pagids. It doesn't sound like boiling fluid is your issue but perhaps try switching pads and see if that helps.
2021 Alfa Romeo Stelvio Quadrifoglio | 2.9L | Trofeo White Tri-Coat | 8-spd
MisterClutch888552.00 |
03-12-2018, 01:46 PM | #21 |
8
Rep 47
So another weekend and another test. Here is what I did and my results - I switched to using a more aggressive pad upfront (had a half warn set of old PFC 01's). Brake temps flipped and I was at about 550 up front and 500 in the rear. I'm going to chalk it up to the car, even though it freaked the track side mechanics at VIR (who also do my work) out.
Temps where talked with a heat gun. |
03-12-2018, 01:49 PM | #22 |
8
Rep 47
Interesting about the boiling fluid....the only time I have had issues on a range of tires, was when some F'ing idiot (me) put in two much oil because we dont have a dip stick and the added pressure had oil all over the engine compartment, which found its way to my brake calipers and then caused my far other side to completely overheat stopping the car.
