Pandora Car Alarm System
Go Back   BMW M3 and BMW M4 Forum > Classifieds > Members Classifieds > Engine / Drivetrain / Exhaust / Bolt-ons
      02-23-2018, 10:01 PM   #1
AW M4
AW M4's Avatar
Drives: F82 ///M4
FS: JB4 w/ OBDII & USB datalogging cable
Sold
FS:
JB4 w/ OBDII & USB data logging cable
Newest Rev 3 model with aluminum enclosure
Lightly used everything is in mint condition
** Not the most recent update & perfect for those who are running catless downpipes that want the check engine light (CEL) delete feature **
Price:
SOLD
JB4 Map Guide
Map 0: Disable JB4 / Full Pass Through Mode
Map 1: Stage1 map adding approximately 40whp and 40wtq across the power band on pump gas. Suitable for all stages and fuel mixtures.
Map 2: Slightly more aggressive version of map 1 intended for vehicles with exhaust modifications and 93+ octane fuel. Can also be used with E85 and racing fuel mixtures.
Map 3: Slightly less aggressive version of map 1 intended for vehicles running on lower grade fuels such as 91 octane.
Map 4: OEM performance but with JB4 active for diagnostics only.
Map 5: //M low torque / linear throttle map.
Map 6: Custom tuning map.
Map 7: Race gas map. Requires 100 octane unleaded fuel and for the fuel mass connector to be installed. This map can also be used with up to 35% E85.
Map 8: Methanol injection map. Requires BMS FSB controller or methanol kit for progressive mapping and safety systems
OBDII In Dash Menu
0 map menu, map shown on tach (TACH shows Map)
1 Active Sound MUTE. (OFF tach = 0, ON tach = 1000)
2 Boost gauge on fuel, scaling in dash is 0 to boost safety setting, turns on when gas pedal is pressed 50% or more and turns itself off when you resume low throttle use. (OFF tach = 0, ON tach = 1000)
3 LED MAX brightness mode. For those with factory LED headlights this option brightens HALO during nighttime operation. (OFF tach = 0, ON tach = 1000)
4 Delete Fault Codes.
5 1st gear boost limiter. (Tach = boost cap / 3)
6 2nd gear boost limiter. (Tach = boost cap / 3)
7 3rd gear boost limiter. (Tach = boost cap / 3)
2015 BMW F82 M4
      02-28-2018, 09:18 AM   #2
AW M4
AW M4's Avatar
Drives: F82 ///M4
Bump!
2015 BMW F82 M4
      03-07-2018, 02:18 PM   #3
kingofqueenz788
kingofqueenz788's Avatar
Drives: F80
Still available ? Txt me 5167291099
      03-07-2018, 04:29 PM   #4
AW M4
AW M4's Avatar
Drives: F82 ///M4
Text coming your way!
2015 BMW F82 M4
Tags
exhaust valve controller, jb4, obdii, pigggyback, tune
f80post
