02-07-2018, 07:33 AM | #1 |
442
Rep 784
Metal Tyre Valve caps
Has anyone had the problem of their metal caps being stuck to the TPMS and not being able to unscrew them off?
I have this problem and not sure what to do? Any suggestions before contemplating having to change all four TPMS
Old Wheels - X5M50d in Carbon Black
New Wheels - X7M50d in Phytonic Blue |
02-07-2018, 07:44 AM | #2 |
231
Rep 1,066
Drives: 2015 X5 50i M Sport
Heat the metal cap up so the metal expands a little bit to loosen up.
2019 Cayenne Turbo
Gone but not forgotten: 2006 2.0T A4 Avant, 2007 Z4 Roadster 3.0si, 2006 M Roadster, 2013 550i M Sport, 2015 Cayman S, 2015 X5 50i M Sport |
02-07-2018, 09:25 AM | #3 |
14
Rep 30
Metal Valve Caps
As already mentioned, try heating them slightly then carefully use grips to release them, carefully working the valve backwards and forwards. Do not force the cap otherwise you run the risk of stripping the threads.
Also spray WD40 or similar release agent onto them and then soak a small strip of cloth with same agent and tie it around the valve, leaving it overnight if possible as this will keep the agent in contact with the valve, allowing the corrosion to soak/wick it up and soften the rust. When fitting them smear a very small amount of copper grease or similar onto the threads of both the valve and cap, making sure to clean any excess off. If all else fails, CAREFULLY use a Dremel or similar and VERY, VERY CAREFULLY just run a VERY SHALLOW cut up the valve cap in a couple of places, but take care not to cut into the main valve body. Please let us know how it went. Hope this helps . |
02-08-2018, 07:34 AM | #5 |
442
Rep 784
Yes I know lesson learned this time
02-08-2018, 07:36 AM | #6 | |
442
Rep 784
Just purchased a Dremel if all fails.
02-08-2018, 07:59 AM | #7 |
398
Rep 648
Unless I'm wrong, you should only need to order new valve stems for the TPMS. (much less expensive than complete units...)
Actual TPMS wheel module,screws onto the special valvestems. (at lease this was the case with wheels on my older BMW's) Still a lot of work to replace though, due to removal of tires. Seems like all the TPMS valve stems I have dealt with, have had corrosion problems (winter and salt conditions), so I put some light grease on the treads these days. |
