02-05-2018, 02:12 PM | #1 |
19
Rep 141
Bought a Canadian car
Bought a Canadian X5 5.0 the other day (I live in Detroit) and I've noticed that navigation traffic was not updating. Also I tried to add the vehicle to my connect app on my iphone and I keep getting an error that its not equipped for connecteddrive services, but I know it has all the hardware and options needed. Been on the phone with dealers service department, BMW assist and each points the finger to the other. Is it something needed to do to make the car work on the US network? do I need new hardware or can I code it myself? did anybody else has any experience bringing a Canadian car in the US?
I would appreciate any direction. Thanks |
02-06-2018, 12:30 AM | #2 | |
123
Rep 126
For remote services, there is BMW Remote app, that can be downloaded and used. Sad and sucks!! |
02-06-2018, 12:48 AM | #3 | |
197
Rep 535
Present: 2014 X5 50i
3rdRow;ACC;HK;HUD;X5M Filters;Bootmod3;FenderFlares;NBTevo6+ATM+carplay; MPBK;612m;X5M-CF-rear-view-mirror-cover;ALPjammer;eurostyle-mirrors Past: 2013 750i xdrive, 2008 535xi |
02-06-2018, 07:40 AM | #4 |
19
Rep 141
Canadian car
Using the new app would had been great in particular heating the car up on some cold Michigan mornings, but not overly concerned if not. I would love to have the traffic updates though. I wonder if there is anything else that I need to do to make sure the car is fully registered on the US network.
02-06-2018, 07:41 AM | #5 |
19
Rep 141
app
Anki, what is BMW remote app, other than the connected app I don't see one.
02-06-2018, 08:23 AM | #6 | |
3945
Rep 2,393
I thought just the 40e X5 can heat and cool with the app?! 35i, 35d and 50i just have the ventilate car option with ConnectedDrive. If I am wrong, I apologize...but I do not believe the 50i can be remotely heated.
02-07-2018, 12:39 PM | #7 |
19
Rep 141
I wasn't aware that it was only ventilated, I do not want to retrofit with a remote starter thought setting to heat up was an adequate alternative. How about the navigation updates though, what do I need to do to enable them to work in the US?
02-07-2018, 12:59 PM | #8 | |
197
Rep 535
Also you will have to figure out which BMW app you can use and what the login is. For 2013-2015 in Canada, we had to use the old BMW remote app, not the new connected drive apps. There is a tread here on BMW connected services Canada login, you can set that up also and see when these services are expiring or what has expired.
02-07-2018, 01:34 PM | #9 |
57
Rep 44
I have had the same issue on my F16 X6. However, it was not a Canadian car, but a European re-fit car. My X6 was originally built and shipped for an executive over in Europe then brought back to Spartanburg, SC to get re-fit to US standards. According to the VIN I had Connected Drive and RTTI, but was never able to get them to work. Spoke with ConnectedDrive people who said that my car did not show up as having the necessary equipment. My, and other, dealers confirmed that my car had the equipment and just gave me a shrug of the shoulders and didn't know what to do because they have not seen this situation before. I persisted enough that my claim went all the way to the highest level of BMW engineers and they eventually got it working. My SA had no idea what they did, but one day it just worked....out of the blue. My advice is to be persistent and don't take no for answer (in a reasonably cordial manner). If your VIN says its available on your car, then something can be done. Good luck.
02-07-2018, 04:18 PM | #10 |
19
Rep 141
I just spoke to someone in a dealer assist hotline, I wasn't supposed to have that number but I called them anyway, (they thought I was a dealer). He said that my car needs to go through a warranty validation process and i should be fine after that. I called customer care and its a form I need to complete to have the warranty moved over and i should be fine after that. Dealer had no idea what I was talking about, I even called the warranty department!!!
