01-24-2018, 12:20 AM | #1 |
892
Rep 9,032
Bugatti Titatinum 3D printed Caliper.
It takes 45 hrs to print each caliper. Looks freaky
https://www.autoblog.com/2018/01/23/...usauto00000016 .
Let me get this straight... You are swapping out parts designed by some of the top engineers in the world because some guys sponsored by a company told you it's "better??" But when you ask the same guy about tracking, "oh no, I have a kid now" or "I just detailed my car." or "i just got new tires."
01-24-2018, 07:32 AM | #3 |
11586
Rep 12,726
i was wondering the same thing... maybe something like tiny laysers of microscopic welds?
Instagram; @roastbeefmike
01-24-2018, 08:11 AM | #5 | ||
Stop the hate, get a V8
3850
Rep 8,625
From Reddit: In short: you have a table with a thin layer of metal powder (copper, iron, aluminium...), then an LASER melts the metal powder where you want your finished peace to be solid. After that the table moves down a little bit and a new layer of powder is placed above the welded layer. Then the cycle begins again, the new layer gets melted at the regions you need it and moves down... tl;dr : LASERS
Now: 2017 Corvette Grand Sport, 2021 AMG C63 S sedan
Past: 2011.5 M3 sedan ZCP |
roastbeef11586.00 SYT_Shadow11490.00 |
01-24-2018, 09:45 AM | #8 |
1026
Rep 842
Impressive tech to be sure, and it looks very similar to AP Racing's Radi-CAL designs. For reference, the current Bugatti Chiron caliper is made by AP Racing and pictured below. We had one come through our facility a while back on its way to a trade show. I lined it up with one of the CP9660 calipers we use in our Essex/AP Racing BBK's. It was a big dog.
01-24-2018, 12:33 PM | #10 | |
336
Rep 724
Down the road from me GE is 3D printing components for jet turbines. In talking with some engineers there, it seems that building in various channels for cooling is one advantage of 3D printing. Given the same geometry not sure if a 3D printed part would have same strength as a forged component. Forged wheels are stronger than cast as an example. |
01-24-2018, 12:34 PM | #11 | |
3850
Rep 8,625
Technically it's laser sintering. They may need to machine key areas since the process leaves a grainy finish, but that's not terribly difficult. https://en.wikipedia.org/wiki/Direct...aser_sintering One of the big benefits with this is they won't need to make molds which are expensive and wear out. The end-to-end production time (design, testing, validating, tweaking, manufacturing, etc) is hypothetically much faster.
Past: 2011.5 M3 sedan ZCP Last edited by dparm; 01-24-2018 at 12:53 PM.. |
roastbeef11586.00 |
01-24-2018, 12:57 PM | #12 | ||
11586
Rep 12,726
01-24-2018, 08:42 PM | #13 | |
3850
Rep 8,625
It's not an illusion: that process doesn't give a smooth finish. It will look gritty.
01-25-2018, 06:12 AM | #14 | |||
336
Rep 724
The internal holes for the fluid would likely be designed in, at least that is touted as a great advantage of 3D printing. The threads for the brake line would also likely be cut/finished after printing. No doubt that for a small production item 3D printing is more cost effective. Also it may allow for difficult to work materials to be used. However, materials develop structures that can add or subtract strength depending on the manufacturing process. Parts design should balance functionality and cost. For high volume items piece rates can be higher with traditional manufacturing methods at least for today. |
roastbeef11586.00 |
