01-23-2018, 07:11 PM | #1 |
467
Rep 818
Stoptech ST60/ST40 Rotor change
Can anyone tell me if you can remove the rotor without removing the caliper on the Stoptech ST60/ST40 BBK's? It looks like it would be possible if you just remove the pads first.
The reason I ask is that I have a stud conversion so I definitely can't; however, I might go ahead and change out my studs at the same time if it saves me pulling the whole caliper off. Removing and re-torquing the caliper carrier bolts is royal PIA so I'd rather not do that. My rotors have lasted almost a year anyhow so changing them at the same interval makes a lot of sense. |
01-23-2018, 07:17 PM | #2 |
403
Rep 1,171
Must at least loosen the two caliper carrier bolts . This will allow you to "wiggle" the rotor off. Not that hard to loosen and then retorque this two bolts imho.
macdude357467.00 |
01-24-2018, 12:11 PM | #3 | |
467
Rep 818
The jet nuts are easier to remove but the last time I did that, the whole stud came out of the carrier and it ruined the carrier and I had to buy another one so I'm paranoid about removing the jet nuts. |
01-24-2018, 02:06 PM | #4 |
403
Rep 1,171
I'm talking the two bolts that hold the bracket to the car's hub. They are easier to loosen and tighten. I use a 1/2" or 3/8" torque wrench from Harbor Freight to tighten to spec. (I believe is 80 ft/lbs)
