BMW X5 and X6 Forum 2014-Current
      01-20-2018, 08:08 AM   #1
Pigdog
12
Drives: 2006 Z4M
2006 BMW Z4M  [9.00]
Verde Empire
Anyone have experience with these?
VERDE® - EMPIRE Matte Graphite (20" x 10", +42 Offset, 5x120.65 Bolt Pattern, 74.1mm Hub) more details on - https://www.carid.com/cart.php
      01-20-2018, 08:09 AM   #2
Pigdog
12
Drives: 2006 Z4M
2006 BMW Z4M  [9.00]
https://www.tirerack.com/upgrade_gar...raphite+Silver
      01-20-2018, 05:24 PM   #3
spike5150
422
Drives: 2020 X5 M50i
Links aren’t pointing to what you want us to see?
      01-20-2018, 06:28 PM   #4
yewlock
yewlock's Avatar
Drives: X5
Link are pointing to my previous interested item.
      01-20-2018, 06:46 PM   #5
DuSh
DuSh's Avatar
2114
Drives: F15 X5 50i
This is their ebay store: https://www.ebay.com/itm/Verde-Empir....c100011.m1850
It's a usual average quality wheel. It will fit. Weighs 36.1lbs - which is not bad for a 20'' rim. Check their warranty and go for it if you like design and color
P.S. 42mm offset is 5mm closer to brake calipers compared to stock 37mm offset - but it will fit without issues - there's more clearance than 5mm
      01-20-2018, 08:33 PM   #6
Pigdog
12
Drives: 2006 Z4M
2006 BMW Z4M  [9.00]
http://verdewheels.com/Default.aspx?...ame=V44-EMPIRE
      01-20-2018, 08:34 PM   #7
Pigdog
12
Drives: 2006 Z4M
2006 BMW Z4M  [9.00]
Sorry for the previous bad links.
      01-20-2018, 08:51 PM   #8
DuSh
DuSh's Avatar
2114
Drives: F15 X5 50i
Just one more thing to keep in mind, tho I'm sure it's going to be fine: rims with tiny thin spokes like in that Verde Empire - they look good, but we have 5300lbs vehicle and depending on your local roads may break, since they are usually not really rated for such heavy cars. It's rare, but it happens, so make sure they have 50i in their supported vehicle lineup and that they have structural warranty
      01-21-2018, 09:14 AM   #9
Pigdog
12
Drives: 2006 Z4M
2006 BMW Z4M  [9.00]
So...
Since the offset is 5mm off should I correct that with a spacer?
      01-21-2018, 09:29 AM   #10
P1
P1's Avatar
11572
Drives: 2004 3/4 ton Duramax
Aren't there any OEM wheels you like? To each their own, but the above wheels don't look that great.
      01-21-2018, 09:55 AM   #11
Pigdog
12
Drives: 2006 Z4M
2006 BMW Z4M  [9.00]
P1et
No sir on the oem...prefer this style of wheel that BMW does not offer.
I think they will look great on my space gray 50i You and I will have to differ on their aesthetic value.
      01-21-2018, 09:59 AM   #12
Pigdog
12
Drives: 2006 Z4M
2006 BMW Z4M  [9.00]
Plus they look way better than this IMHO
https://photos.app.goo.gl/Lo5lHj8rcEn7jrl12
      01-21-2018, 10:39 AM   #13
CeeTeeX5
936
Drives: 2018 X5 xDrive35i M-Sport
Check out VMR or Avant Garde. Similar in design and a lot of bmw drivers running them. I think Avant Garde are low gravity cast so should he stronger than your standard cast wheels.
      01-21-2018, 01:07 PM   #14
DuSh
DuSh's Avatar
2114
Drives: F15 X5 50i
So...
You can, but it's not necessary, it all depends on what tires are you planning to run and if you have fender flares or not? Basically you need to check your tires won't be sticking out too much
Many of us here run 5mm/15mm (front/rear) spacers from rg33 just to make it look flash (or more aggressive than stock recessed look), but we are staggered and have fender flares
IMHO - I would not rush buying something until you are 100% sure you want that look - easy to buy, but very hard to sell if you quickly realize you didn't like the looks. I would start by checking photos of a setup you like mounted on the x5 and then adjust a bit with spacers if you want a bit more aggressive look
20 inch rim is a nice choice - cheaper tires and wheels weigh less (not sure if it's important for you - dynamics). However, if I was to redo it - I would go for 21 or 22 with lightweight forged rims - expensive, but you do it once and do it right imho
      01-21-2018, 06:29 PM   #15
Pigdog
12
Drives: 2006 Z4M
2006 BMW Z4M  [9.00]
Wow like the VMR V710.
Who is a good wheel tire vendor?
      01-21-2018, 10:28 PM   #16
redline9001
redline9001's Avatar
223
Drives: E92 M3, F15 X5, G14 F150
I had VMR 710 on my m3 for winter wheels, my friend is now running them on 335 for winter rims. The are good quality and have held up for many years now Of winter driving.
They are a good choice.
2011 E92 M3 | JEREZ BLACK | EXTENDED BAMBOO NOVILLO | EXECUTIVE PKG | M-DRIVE | EDC | M-DCT
MODS | KW S/O | HRE P40SC | Akra Evo |ESS Akra Tune | ESS DCT tune | BMC drop in | StopTech Trophies | TMS Pulley | LUX V3 | BE Bearings and BE ARP rod bolts
      01-21-2018, 10:40 PM   #17
CeeTeeX5
936
Check out Mod Bargains. They carry vmr and avant garde I believe. I almost ordered a set of avant garde from them but ended up getting a deal on a set of Vossens.
      02-13-2018, 09:24 AM   #18
Pigdog
12
Drives: 2006 Z4M
2006 BMW Z4M  [9.00]
What do you think?
      02-27-2018, 10:48 AM   #19
yllwwgn
yllwwgn's Avatar
170
Drives: 2018 X3 M40i
Location: Milky Way, Earth, North America, Arizona more specifically.
What do you think?
Love these! Can you post any more pics, like a side shot and one from the back of them... curious to see how much the spokes stick out. Thank you!
      02-27-2018, 10:53 AM   #20
Kzang
Kzang's Avatar
3240
Drives: 2015 X5 35i Msport SG
What do you think?
Looks hot! but I think you should of gotten 22" or even 21".
Those looks really small in proportion to the car.
2015 F15 X5 35i Msport Space Grey M Performance parts MPPK, MPE
xbimmers
