01-18-2018, 11:15 AM | #1 |
39
Rep 126
Macht Schnell Exhaust Valve Control (EVC) Module
Up for sale I have a gently used Macht Schnell EVC module that I have used for a few thousand miles. I bought it brand new and comes with wiring harness,clamps, and box. Just switched to a new tune and now longer need. $250 shipped. Thanks for looking. Compatible with all exhaust systems (OEM or aftermarket) that retain the factory EVC control, the Macht Schnell Exhaust Valve Control (EVC) Module allows FULL user control of your exhaust system at the touch of a button. No clumsy key FOBs or additional equipment is needed - this is a 100% integrated solution and the first of its kind for current BMW models. BMW's Exhaust Control Valve is integrated at the exhaust system end pipe of the muffler. The exhaust flap reduces the noise level when the engine is idle and when the engine speed is close to idle. This reduces the outlet noise to improve comfort to the driver. The reduction on a stock exhaust system is ~8dB on the stock exhaust system. The Macht Schnell EVC Module supports the following features: - FULL control over Exhaust Valve Control at the touch of a button - on the fly or while stationary - User settings configurable by computer or while installed in vehicle from driver’s seat - Open/Close Exhaust Valve at YOUR command, or use BMW's factory profile for Exhaust Valve Control - Optional User-defined Valve Control Setting at startup (Open/Closed) or default to OEM operation - Quiet Cold Start in mornings compared to OEM operation - Integrated USB port for feature updates and configuration changes - InstallAID integrated LED confirms proper installation/operation while in use - Clears CEL Codes - Folds mirrors in - Regulated internal power supply enters sleep mode to prevent unnecessary power drain while vehicle is parked - Easy 20-minute installation process with no wire cutting - No dealer visits or coding required after installation - Completely removable at any time Last edited by jerryj20; 02-01-2018 at 12:46 PM.. |
