BMW X5 and X6 Forum 2014-Current
      01-17-2018, 03:30 PM   #1
fromkrypton
611
Drives: 2015 X5 35d
2015 BMW X5 35d  [0.00]
I'm thinking it's about time to change my pads and rotors.
Should I go OEM bmw parts or aftermarket? I was looking at Hawk or stop tech cross drilled rotors for looks.
What do you guys think? OEM or other? The non oem do come out much cheaper, Hawks are $350shipped for all 4 corners.
      01-17-2018, 04:00 PM   #2
DuSh
DuSh's Avatar
2114
Drives: F15 X5 50i
Hawk has better performance than oem pads, so if you want a bit better stopping power and initial bite Hawk is the way to go. Even Porsche guys go with Hawk.
As for rotors - nothing beats oem in terms of durability. However, I went with Stop Tech drilled and slotted rotors just for looks too. Picking them up today and going to install them soon. Will post pics. I'm not expecting them to be as good as oem ones, but close enough is all I need
Do you have 50i or 35i/35d?
      01-17-2018, 07:21 PM   #3
fromkrypton
611
Drives: 2015 X5 35d
Got the 35d. I don't drive hard at all, even got it coded to start in ecopro
      01-17-2018, 07:53 PM   #4
vympel777
vympel777's Avatar
31
Drives: 540 B58 MSPRT \ F16 5.0 M SPRT
If you want to save some $ zimmerman coated is the way to go. I used them on both e70 and f15. I felt almost no difference but a significant improvement. As for brake pads texter seems to produce less dust and decent stopping power. Just note that non oem parts can void ur warranty not sure if that applies to rotors since they are not covered under bmw warranty lol
DuSh2113.50
      01-17-2018, 08:03 PM   #5
DuSh
DuSh's Avatar
2114
Drives: F15 X5 50i
Yes, warranty is always the risk unfortunately one has to consider. I'm glad I'm almost done - mine ends on March 2018 (free maintenance one)
      01-17-2018, 08:03 PM   #6
fromkrypton
611
Drives: 2015 X5 35d
Everything in Canada seems to good the bmw warranty or just isn't covered by the bmw warranty lol
I'm definitely not worried about that considering I'll even be doing the work myself
DuSh2113.50
      01-17-2018, 08:31 PM   #7
yewlock
yewlock's Avatar
Drives: X5
I will go for Hawks pad. I have good experience with them. I will also go for aftermarket drilled rotors for the looks.
      01-18-2018, 09:09 AM   #8
vympel777
vympel777's Avatar
31
Its up to you mate but every drilled / slotted rotors I had was complete disappointment. Hawks are good pads tho.
      02-04-2018, 10:18 AM   #9
fromkrypton
611
Drives: 2015 X5 35d
Been eyeing this set. Any thoughts?
      02-04-2018, 10:32 AM   #10
motex
2020 Mineral White 30d MSport
motex's Avatar
Costa Rica
524
Drives: 2020 Mineral White 30d MSport
What's your actual mileage?
....Life is too short to drive boring cars
      02-04-2018, 12:07 PM   #11
fromkrypton
611
Drives: 2015 X5 35d
60000 miles
      02-04-2018, 12:15 PM   #12
pits200
Drives: 09 335i X-Drive Black Sapphire
Does anyone know the rotor thickness minimum? I'm having a hard time finding this value and not sure if the rotors have ever been changed on this vehicle and want to know if it needs done.
Thanks
      02-04-2018, 03:04 PM   #13
DuSh
DuSh's Avatar
2114
Drives: F15 X5 50i
Thanks
So for 36mm ones - minimum is 34.4mm for disks and 3.7mm minimum for pads (light indicator should come on at that point for pads)
I got it here: https://www.newtis.info/tisv2/a/en/f...kes/1VnYYwj5Wn
      02-04-2018, 03:10 PM   #14
DuSh
DuSh's Avatar
2114
Drives: F15 X5 50i
So for StopTech rotors - so far I can't notice any difference with oem ones - maybe it's too early to tell, but I think it's a good thing. Well at least StopTech makes bbk too and they are probably almost as famous as Brembo (not really, but almost) - meaning they don't produce right out bad things - they are pretty descent
As for pads: Hawks or Carbotech - both are good pads recomended to improve stopping power over oem pads (carbotech also reduces brake dust)
I'll be installing F85 rotors on front axle instead of my current Stoptech ones and if I was closer to you, I could have just gave it to you for free, they have only like 500 miles on them (just installed them 2 weeks ago), but shipping will be expensive
BTW, before you buy, consider doing same as I did: I bought E70 X5M stock oem Brembo (set of 2 front calipers) for $800 on ebay. They bolt on directly without any modifications. You can paint them any color yourself (very easy to do with VHT caliper paint before you install them). Then you can match them with F85 drilled rotors - 395mm (they go for $320 on bmwpartsnow). You'll have a gorgeous looking bbk for total of $1.4-1.5k - the good thing about it is that you can always sell them later and recuperate money - they are in high demand
      02-04-2018, 03:22 PM   #15
CeeTeeX5
936
Drives: 2018 X5 xDrive35i M-Sport
I ran this setup on my E46 M3 but with slotted rotors instead of the drilled ones. They were great and I had no issues with them. I put about 20k on them before I sold the car.
      02-05-2018, 06:38 AM   #16
fosterelli
237
Drives: 2014 X5 xDrive35i M-Sport
PM Sent.
2014 X5 x35 F15
      02-05-2018, 12:36 PM   #17
Spydeputy
Spydeputy's Avatar
Germany
205
Drives: 2015 F23 M235i/2008,E90,335xi
Don't worry about the thickness, BMW "NEVER"
reuses the rotors. Always replace them.
Thanks
      02-05-2018, 12:47 PM   #18
DuSh
DuSh's Avatar
2114
Drives: F15 X5 50i
Yes, but in order to know WHEN to replace - you need to know remaining thickness lol - that's how BMW checks rotors. It's not like they go randomly and replace rotors on every oil change
P.S. Am I the only one here who follows logic
      02-05-2018, 01:05 PM   #19
CeeTeeX5
936
Here you go, for 35i or 35d.
Front: 28.4mm
http://www.realoem.com/bmw/enUS/part...&q=34116868939
Rear: 18.4mm
http://www.realoem.com/bmw/enUS/part...&q=34216886479
      02-05-2018, 01:11 PM   #20
CeeTeeX5
936
Dush, that's for the X5m. Pits, what do you drive?
      02-05-2018, 01:35 PM   #21
dagwoodnil
11
Drives: 2014 X5 35d, 2017 M2 MGM MT
2014 BMW X5 35d  [0.00]
2009 BMW Z4 35i  [0.00]
I just changed my rear pads also (@ 65k km)
My guy used these pads. (http://textar.com/passenger-cars/textar-epad/)
I had them on my Z4 before. Good stopping power and very low dust.
Something strange, My rear brakes needed replacing but the front pads still had lots of life left in it.
Usually, its the front pads that goes first.
Anyone else notice that in their X5?
      02-05-2018, 01:41 PM   #22
Doanster
Doanster's Avatar
627
Drives: 2014 F15 Carbon Black M-Sport
Exact same here. Our X5s must be seriously rear-brake-biased.
A little mod here, a little mod there...
xbimmers
