01-17-2018, 09:00 AM | #1 |
12
Rep 35
295/35/21 Square Set Up
Is this possible? Anyone have this set up?
Thanks |
01-17-2018, 03:01 PM | #3 |
1176
Rep 842
Recommended wheel width is 10"-11.5"
Assuming your wheels are staggered, the rear tire will be stretched.
'23 B8, '84 Monte Carlo SS, '23 Escalade, '21 S 580, '20 AMG GT 53 , '18 LS 500, '18 X6, '16 Corvette, '12 750Li, '14 GS 350, '13 ES 350, '10 Maxima, '09 Challenger |
01-17-2018, 03:38 PM | #4 |
12
Rep 35
No...I was looking foe a square set up so I could rotate. I really don't see the need to stagger SUV tires.
The problem for me is finding a affordable 21" wheel I like plus Conti DWS06 are >1200.00 in this size. |
01-17-2018, 04:04 PM | #5 |
2114
Rep 2,388
They'll fit without issues, just make sure you have correct offset for rims depending what look you are going for: flush or stock. 295mm for front axle is bigger than I would go, but people have put even 315mm on front - just need proper offset for that. So it all will depend what rims you are going with?
01-17-2018, 06:38 PM | #7 |
12
Rep 35
I cant find a 21 inch forgestar...
01-17-2018, 06:42 PM | #8 |
1176
Rep 842
01-17-2018, 08:06 PM | #9 |
2114
Rep 2,388
When you'll decide which rim CF10 or another - just plug in numbers into this offset calculator and check if it fits and how much it will stick out if any https://www.wheel-size.com/calc/?whe...cl=50mm&sr=0mm
On left side you can plug in stock 21 inch size specs to compare to your aftermarket setup on right side |
