01-08-2018, 12:12 PM | #1 |
New Lifetime Replacement Policy
815
Rep 11,738
New Schwaben Fender Roller! $59.95* with Free Shipping!
This professional-grade fender roller allows you to gently and gradually flatten your inner fender lips in order to increase your fender to tire clearance. This is the perfect tool for: If you want to lower your vehicle If you want wider-than-stock wheels If you are going to use wheel spacers or decreased offset By rolling the fender lip flat, you can lower your car further, and give your car a wider stance, without your tires rubbing on the inside of the fender. Fully adjustable for use on vehicles of different ride heights, offsets, and wheel bolt patterns. Fits 4 and 5 lug hubs with up to 120.6mm (4.75") bolt patterns. Click HERE for your Schwaben Fender Roller! After you get yours make sure to post you in-use as well as before and after images here! *price subject to change |
