BMW X5 and X6 Forum 2014-Current
      12-26-2017, 01:36 AM   #1
CeeTeeX5
936
Drives: 2018 X5 xDrive35i M-Sport
285/35/22, will it fit??
Driving a xDrive35i with the M sport package. Would 22x10 with 285/35/22 fit? Anyone running this setup? I know the overall diameter will increase which is my concern but I’d prefer the addtl sidewall.
      12-26-2017, 07:22 AM   #2
menelaos
menelaos's Avatar
1226
Drives: 2015 BMW X5 F15
Fitment
Technically speaking, because I asked the same questions, your tire diameter should not exceed 29''. My control arm's distance from the top of tire is less than 3/4''. So if your tire, and this is for the front, is higher that 29.3'', you're in the "danger" zone.
If you go to tirerack, and you enter 285/35/22, you'll see that the diameter of these tires -inflated- are close to 30''. So I don't think it would fit.
      12-26-2017, 09:22 AM   #3
CeeTeeX5
936
Thanks Menelaos, what size did you end up running?
      12-26-2017, 10:05 AM   #4
cvillanFL
Drives: 2017 BMW X5 40e
I'm running 295/30/22 on my fronts (22x10) and 335/25/22 on the rears (22x12). No issues.
      12-26-2017, 10:35 AM   #5
menelaos
menelaos's Avatar
1226
Am debating my summer set...right now running 255/50/19.
Am looking into summer set combinations. A lot of choices in 20s, 21s and few 22s
      12-26-2017, 10:38 AM   #6
menelaos
menelaos's Avatar
1226
285/35/22 has higher diameter than 295/30/22. About an inch difference in those I sampled in tirerack
Will you be able to measure the horizontal and vertical distance from the control arm and let us know? Am intrigued by your setup, but I don't want any rubbing.
Please share the offsets on wheels if you could!
      12-26-2017, 10:56 AM   #7
P1
P1's Avatar
11572
Drives: 2004 3/4 ton Duramax
Be very careful with your xDrive.
      12-26-2017, 12:23 PM   #8
CeeTeeX5
936
I would run a square setup so my understanding is this shouldn’t be an issue? My main concern is clearance within the wheel wells.
Could you guys share your offsets as well?
      12-27-2017, 02:31 PM   #9
CUPID G05 X5
22
Drives: 2020 G05 X5
yeah I'm running 295/30/22 front and 335/25/22 rear on a 35i m sport
      12-27-2017, 05:22 PM   #10
menelaos
menelaos's Avatar
1226
Could you share wheel specs?
      12-27-2017, 05:27 PM   #11
CUPID G05 X5
22
Drives: 2020 G05 X5
front 10.5 rear 12.0 I'm riding on some HR SPRINGS but I'm changing them this weekend for some Eibach the drop is better with Eibach
      12-27-2017, 05:39 PM   #12
menelaos
menelaos's Avatar
1226
What about offsets?
      12-27-2017, 06:01 PM   #13
CUPID G05 X5
22
Drives: 2020 G05 X5
FRONT 22x10.5-ET35-REAR 22X12-ET25
      12-27-2017, 08:06 PM   #14
menelaos
menelaos's Avatar
1226
Yeah, only these offsets can accommodate such wide wheels.
Must be looking like a muscle car....if you could share pics, it'd be great!
      12-27-2017, 08:14 PM   #15
CUPID G05 X5
22
Drives: 2020 G05 X5
I'm trying upload some pics for u but I can't get them maybe I'm doing it wrong
      12-27-2017, 08:25 PM   #16
menelaos
menelaos's Avatar
1226
Come on.. Do it!
      12-27-2017, 08:47 PM   #17
CeeTeeX5
936
File size might be too big. Try uploading to photobucket then use the sharing/embed links. That's what I've been doing. Looking forward to the pics too! 22x12 is wiiiidddeee!!
      12-21-2022, 10:30 AM   #18
Erskine Robertson
Drives: BMW X6 2015
Wheel Fitment
Hi Guys!
After a bit of help as im pretty ignorant on the matter.
I haver an 2015 XDrive 30d. it currently has the 20" wheels on it which I believe they are the original wheels that came with the car. im looking to get a set of 22"s that I have seen and all 4 wheels are 285/35/22. 5x120. The question is will these fit ok?
      12-21-2022, 10:31 AM   #19
Erskine Robertson
Drives: BMW X6 2015
Wheel Fitment
Forgot to Mention its an X6
xbimmers
