12-07-2017, 10:42 AM | #1 |
Rep 28
Will these wheels fit with my 18 M3?
I have an 18 m3 with competition package and just wondering if these wheels will fit (sorry rookie here trying to buy winter tires and wheels)
Size: 19x8.5 Bolt Code: 21 Bolt Circle: 5x120 Offset: 35 Back Space: 6.1 Bore: 72.5 TPMS: Yes Cap: 1003-40MB Finish: Matte Black Face w/Gloss Black Windows Load Rating: 1600 Rim Type: Standard Seat Type: Conical https://www.vividracing.com/catalog/...151848447.html |
12-07-2017, 08:57 PM | #3 |
116
Rep 468
12-08-2017, 04:24 PM | #4 |
Rep 28
12-08-2017, 04:58 PM | #6 |
1973
Rep 2,711
Offset may not clear the front suspension. You will need an 8MM spacer minimum.
ET35 will work for the rear, but 8.5 width wheel will be too narrow. My recommendation would be a square set of Apex ARC-8 19x10 ET25 wheels along with 265/35/19 or 275/35/19 tires all around -- they're currently on sale, and can be had for a very good price. https://www.apexraceparts.com/wheels...eel_diameter=6 |
12-09-2017, 12:23 PM | #7 | |
162
Rep 281
12-09-2017, 08:39 PM | #8 |
1973
Rep 2,711
Better is subjective to the kind of application you're looking for, as well as how much you're willing to spend.
Apex is known for their affordable flow-formed, light weight 1-piece wheels. Many people use them on the track and/or dual purpose (track + daily). They've been the go-to bang for your buck wheels for as long as they've existed. On the other hand, BBS has been around for a very very long time. They know wheels, and they're very good at it. If you're looking for a multi-piece set with a fat lip, you'll most likely be considering either BBS or Work wheels. The only downside to BBS is the price tag. A decent set of BBS wheels will set you back quite a bit, and can easily net you 4 different sets of Apex wheels. |
12-09-2017, 08:45 PM | #9 | |
162
Rep 281
12-27-2017, 01:27 PM | #12 | |
1973
Rep 2,711
Ideal wheel width for the front is 9.5" or 10" with offset between ET22-28 For the rear, it's anywhere between 10" (up to ET25) or 11" (no less than ET40, ET44 recommended). You can run a more aggressive setup if you don't mind dialing more negative camber and/or rolled fenders + shaved plastic liners. This is the way to go if you care more about form over function. |
05-04-2018, 12:47 PM | #14 | |
6582
Rep 5,304
Rear will also need a 12mm - 15mm spacer to sit flushed. Again, depends on what tires you run. A squared 10 inch wide wheel ET40 is not a good size to start with on this car. |
N3_Gabe25.00 |
