      11-24-2017, 08:46 PM   #1
1and1
Loves me some MHD!
1and1's Avatar
Drives: faster than he should...
'09 135i  [10.00]
Installed 1M Rep bumper with 1M ducts
Installed my 1M rep bumper today with a set of 1M ducts replacing the fog lights. Feel free to ask questions and I'll answer best as I can.
Process and massive thanks to 714_1er and his install thread!
http://www.1addicts.com/forums/showthread.php?t=1285727
Saved me hours of work- What you see below took ~3 hours labor.
See attachments below, comments in order...
1) Starting point- You all know this 135 bumper
2) Bumper and original ducts removed
3) Headlight, hl washers and horn bracket removed, first horn mounted 1M style
4) Headlight washers removes and other horn mounted 1M style
5) Driver side ducting mount bolt & nut spacing. Pass side uses original mount points.
6) 1M ducts final mount & spacing
7) 1M ducts, horns mounted, HL washers removed, drivers headlight installed
8) Initial bumper test fitting... Yup, 'bout right
9) Yeah baby...
10) Yeah
1and1
135i - E82.N54 2009 BSM - MHD / xHP / DCI, PR CP & 7.5" Race IC / N55 mid & Borla
. . WL RSFI, Koni, Eibach & Dinan CP's, M3 CA's / EBC Red's & Firehawk 500's
X1 - E84.N20 2013 MGM - JB4 - The Wife's, now with new turbo & ewg
Appreciate 4
Esteban43745.00
Matticus913474.50
      11-24-2017, 08:50 PM   #2
1and1
Loves me some MHD!
1and1's Avatar
'09 135i  [10.00]
Inspecter checked in mid-job...
100+ pound, 13 year old Shepweiler, and total goofball
Bestest good boy, and total guard puppers! Unless you bring treats, then he's best friends...
1and1
Appreciate 3
Esteban43745.00
BAN_M2C4180.00
Matticus913474.50
      11-24-2017, 08:54 PM   #3
jkoral
Drives: 2017 M2 LBB 6MT
Looks great. Did you cut out the fog lights that come in the bumper (I thought almost all the aftermarket 1M-style bumpers had them)?
      11-24-2017, 08:59 PM   #4
1and1
Loves me some MHD!
1and1's Avatar
'09 135i  [10.00]
Yup, before paint- spent about an hour all told, with a jig saw first to quickly & easily get the big areas cut out, then a dremel tool to clean up & fine tune.
1and1
Appreciate 2
Esteban43745.00
Fakemike368.50
      11-24-2017, 10:48 PM   #5
Esteban
Esteban's Avatar
Drives: a slow car fast
Your car looks great with the new bumper!
Love your dog, he looks totally cute! Now that's a best friend!
1and11858.00
      11-26-2017, 03:51 PM   #6
BAN_M2C
BAN_M2C's Avatar
4180
Drives: 991.2 Porsche GT3, BMW E46 M3
1987 BMW 325is  [10.00]
2004 BMW X3  [6.50]
2018 Porsche 911 GT3  [10.00]
1974 BMW 2002tii  [10.00]
2004 BMW M3  [10.00]
This looks great! Love how the pup inspects the job. Mine usually checks every box and all car parts I get.
Follow me on IG
Garage: 2018 991.2 GT3|2013 135i|2004 M3|2004 X3|1987 325is|1987 325i|1974 2002tii
Appreciate 2
1and11858.00
roavar1.50
      11-27-2017, 09:14 AM   #7
Matticus91
Matticus91's Avatar
Drives: 2013 135i
Awesome work man! Those ducts look great, I'll be ordering mine shortly. Just need to get the motivation to pull the bumper off again lol. How was the install process for the 1M ducts? Did you follow those threads?
"Tobias" 2013 135i ///M-Sport 6MT • Pure Stage 1 • XDI 35 HPFP • 404whp/440wtq
1and11858.00
      11-27-2017, 09:55 AM   #8
1and1
Loves me some MHD!
1and1's Avatar
'09 135i  [10.00]
I did, the how-to I followed is linked in the first post. I've got a photobucket hotlink extension that makes the pics work again
Was pretty easy actually- I was surprised. Four hours from on the ramps to off again, and I spent an hour of that farting around with other non-car stuff, so really three hours actual work time. If I were to do it again, probably only take 1.5 or 2 hours.
Pass side is easy bolt in swap.
Pulling the brackets for the hl washers and horns was straight forward. Sharp drill bit is your friend for rivets, even plastic ones. I did try to just knock out the plastic retainer pins, but they weren't having it so after just a few moments they got the drill...
Horns went right in the holes at the end of the bumper, and wiring is already on the passenger side- they actually just ran an extension over to the drivers side for the horn. Just remove that extension and you're all set- pretty darn handy.
I've had my HL washers deactivated since I got the car, so was happy to pull em out. Disconnected the line at the connection by the passenger side headlight.
Used the bolt with 4 nuts to act as spacer/alignment. Probably spent the most time getting this right. There is a pic showing this in the first post. Two nuts hold the duct in place, and two hold the bolt to the frame. No bolt specs, was just pulled from my leftover bolt bucket.
And I'm totally tickled with how it came out. I'm pondering what to do, if anything, about the small gaps to the fender liners and on the outer edges where duct meets bumper. May not do anything- they really don't bother me at the moment, and are small enough that you don't see em unless you're at just the right angle.
1and1
      11-27-2017, 02:06 PM   #9
Mr. Pharaoh
61
Drives: 2013 135i coupe
Looks awesome! And I love the dog too. Which rep bumper did you go with?
      11-28-2017, 09:35 AM   #10
1and1
Loves me some MHD!
1and1's Avatar
'09 135i  [10.00]
Thanks!
I have no idea who actually made the bumper- it's a random imported knock-off from ebay. Link is below, tho it's no longer active you can at least get an idea to compare against... I was surprisingly pleased with the quality.
https://www.ebay.com/itm/BMW-1-Serie...s/182682923468
1and1
      11-30-2017, 05:35 PM   #11
1and1
Loves me some MHD!
1and1's Avatar
'09 135i  [10.00]
I've got a name... Still a random import knock off, but here ya go- So, the ebay listing said the manufacturer was "Good Go" which I giggled at, but sure enough that's the company name! And I have pics to prove it..., well, at least that's the name on the box and plastic wrapper...
1and1
      12-07-2017, 06:24 PM   #12
shawnj
45
Drives: 135i
This looks soooo much better than those stupid fogs. Good shit!
1and11858.00
      12-07-2017, 07:58 PM   #13
1and1
Loves me some MHD!
1and1's Avatar
'09 135i  [10.00]
Thanks!
I'm still really enjoying it, loving the aggressive look.
1and1
      12-14-2017, 06:22 PM   #14
remorse
Drives: 135i
I'm wanting to get one of these bumpers, however I cannot find anyone willing to ship to New Zealand :/
      01-12-2018, 08:20 AM   #15
low135
2213
Drives: E88 135i
This really does look so much better with the ducts. Would love to see this on a white car for the contrast
      01-16-2018, 05:48 PM   #16
1and1
Loves me some MHD!
1and1's Avatar
'09 135i  [10.00]
Very pleased with the rep bumper. Many runs to 100+ for short periods, many many many cruises at 80+, all with no issues. Nothing flapping around, nothing rattling, nothing falling off.
Love the look.
Only thing, and I'm reaching here..., in cold temps the oil temp takes even longer to come up- this is expected due to that big 'ol air duct flowing up to the oil cooler. Yeah, not really an issue, but figured I should find some bad(ish...) thing to report
1and1
      08-06-2018, 10:34 AM   #17
StallMaster
StallMaster's Avatar
14
Drives: FBO 135i
Just bought the same one after I saw this post. I am in class right now and could not resist lolllll.
      08-06-2018, 11:54 AM   #18
1and1
Loves me some MHD!
1and1's Avatar
'09 135i  [10.00]
Congrats- hope you like it as much as I do! I've been really pleased with mine!
Oh, and welcome to 1Addicts!
I'm thinking some wheel spacers are next...
1and1
low1352213.00
      10-25-2018, 08:35 PM   #19
1and1
Loves me some MHD!
1and1's Avatar
'09 135i  [10.00]
Wheel spacers added :P
Dinan camber plates in the front, and the Indy 500's run narrow- This combination resulted in running 15mm spacers in the front and 10mm in the rear due to the extra camber in the front. Basic "normal" for stock suspension is to run 10mm f & 15 rear.
I also plan to increase tread width all around in the future, currently stock dimensions.
1and1
Appreciate 2
Esteban43745.00
Blu3RSX27.50
      11-01-2018, 06:35 AM   #20
Blu3RSX
Industrial Designer
Blu3RSX's Avatar
Drives: 2013 135i. It's blu3 ^_^
Looks good! I'm new to the 135i scene *and* in Tallahassee...hope to see you around
Cowl Delete
Injen Intake
BMS Stage 1
BMS Pedal Tuner
ARM 5" Intercooler
Esteban43745.00
      11-01-2018, 08:05 AM   #21
1and1
Loves me some MHD!
1and1's Avatar
'09 135i  [10.00]
Welcome!
Glad to see another 135 in Tally!
1and1
      11-01-2018, 10:48 AM   #22
Esteban
Esteban's Avatar
Welcome...
Post up some pics when you have time.
Blu3RSX27.50
