10-22-2017, 08:46 PM | #1 |
Old man
322
Rep 349
Coding Easy Entry on a 2018 F80
Is it possible to code the Easy Entry feature on a '18 M3?
Did anyone here do it ? Thanks! A
ArieArie
10-24-2017, 07:51 PM | #3 | |
Old man
322
Rep 349
Thanks!! Now I know two things. 1) It can be done, which is great. 2) I can't do it myself. I need to find someone in my area that is good at coding.
ArieArie
10-25-2017, 04:43 AM | #4 |
///M SubDriver
1848
Rep 2,788
Drives: 2017 M3, 2020 X7 40i
Actually, if you get the BimmerCode app for your cell phone, this feature is relatively easy to code. The thread above tells you the parameters that need to be changed. The only extra step outside of the coding is taking the measurements for how far you want the seat to go back.
I did this mod and love it.
///M3 COMPETITION 6MT - 2017 F80 Smoked Topaz Metallic
BM3 / MP-HAS / GC Camber Plates / Carbonstructure Interior X7 XDrive 40i ///M-SPORT - 2020 G07 Arctic Grey Metallic X3 XDrive 30i - 2019 G01 Mineral White (wife's) / 128i 6MT - 2009 E82 Jet Black (son's) |
10-25-2017, 10:49 AM | #5 | ||
BTC maxi
222
Rep 1,124
10-25-2017, 03:21 PM | #6 | |
Old man
322
Rep 349
Thanks for the pointer. I have question about the feature itself. How does it work once coded, does the seat move back when you turn off the car? once you open the door? Does it only control the back and forth movement of the breast or can it also be set up for things like height or recline?
ArieArie
10-25-2017, 03:22 PM | #7 |
Old man
322
Rep 349
No I don't. I do have the Bimmercode app installed and working.
ArieArie
10-25-2017, 09:47 PM | #8 | |
///M SubDriver
1848
Rep 2,788
"This testing process worked for me after coding variables: 1. Door closed, Seat at driving position, Ignition ON 2. Turn Ignition Off, open door. Seat moves back 3. Close door, Turn Ignition ON. Seat moves up" It only controls the back/forward motion of the seat - not the recline. Also, the distance the seat moves back/forward is fixed. So in other words, the seat will not go back to one of your seat preset positions. Whatever the position the seat is in when you turn off the car and open the door, that is a position from where it will move back and return to.
10-25-2017, 11:31 PM | #9 |
I want to drive a Zamboni
1135
Rep 5,561
Drives: 13 E93 M3 18 F80 M3 16 K71
Had the Carly App and I could not get it to work.
18 F80 Imola Red 6MT
16 K71 F800GT Montego Blue 13 E93 M3 Melbourne Red 2000 E46,2006 E90,09 E82,13 E93 328i,14 F30 335i,18 F80 M3 My next vehicle would be a Zamboni |
10-25-2017, 11:59 PM | #10 | |
Old man
322
Rep 349
Now it makes sense. Thank you!
ArieArie
10-26-2017, 11:20 AM | #11 | ||
just a fool
345
Rep 675
I'll add 1 more: As the seat moves forward, if you engage the gearbox, it'll stop moving.That is the only thing I don't like about it as I have to sit there waiting for 2 seconds before I can drive away. I guess it is for safety. |
10-26-2017, 09:49 PM | #12 |
Old man
322
Rep 349
I wonder how would this work with a manual transmission. I Usually start the car in while 1st (clutch in).
ArieArie
10-26-2017, 11:05 PM | #13 |
just a fool
345
Rep 675
10-27-2017, 05:14 AM | #14 | |
///M SubDriver
1848
Rep 2,788
I have found that my normal routine of getting into the car, starting it, seat moving forward and driving off works just fine. In other words, I don't feel like I am awkwardly "waiting" for my seat to finish moving before I drive off. How long that wait is, of course, is determined by how far you want the seat to move. I actually have my seat move farther back than what the link above has you code. It is perfect for me since I prefer a driving position closer to the steering wheel. The distance that I have the seat move back not only makes it more comfortable to get in/out of the car, but it helps to keep some additional wear/tear on the seats getting in/out of the car.
BM3 / MP-HAS / GC Camber Plates / Carbonstructure Interior X7 XDrive 40i ///M-SPORT - 2020 G07 Arctic Grey Metallic X3 XDrive 30i - 2019 G01 Mineral White (wife's) / 128i 6MT - 2009 E82 Jet Black (son's) Last edited by jmciver; 10-27-2017 at 05:43 AM.. |
ArieArie321.50 |
12-04-2017, 09:34 PM | #16 |
2376
Rep 8,364
01-02-2018, 02:27 AM | #17 |
3293
Rep 6,733
07-20-2018, 08:50 AM | #18 | |
48
Rep 309
2018 F80 Thanks |
07-20-2018, 09:41 AM | #19 | ||
///M SubDriver
1848
Rep 2,788
07-20-2018, 11:03 AM | #20 |
48
Rep 309
07-21-2018, 11:25 AM | #21 |
48
Rep 309
Been trying to find the lines to edit how far the seat moves back in my 2018 F80.
I already coded: 3000 EINAUSSTIEGSHILFE set to: Modus_FA_SLV This enabled my easy entry function. Only issue now is that it moves too far back. I've been searching for these two lines but no luck finding them: 3012 EAH_VERFAHRWEG_SLV_PHYS werte = 00, 3C (60mm) 3012 EAH_SCHUTZFREIRAUM_HINTEN_SLV_PHYS werte = 00, 0F (15mm) Am I supposed to be looking somewhere else or did BMW take them out? Thanks for all the help, very much appreciated. |
07-21-2018, 12:07 PM | #22 |
///M SubDriver
1848
Rep 2,788
BMW could have taken them out or "moved" them, which I have seen before. In my case on my '17 M3, I had SMX modules, which were the seat modules (one for driver and one for passenger) which is where those parameters were located.
