10-21-2017, 07:19 AM | #1 |
RetNavSpook
67
Rep 398
Trickle Charger
I had a BMW trickle charger on a 2003 325i which plugged into the unused cigarette lighter socket. Having traded that car in for a 2016 320i can I used the charger on this car? Are there certain specifications that I should look for? All comments are welcome.
10-21-2017, 08:22 AM | #2 |
Bergspyder
1469
Rep 1,212
Lighter socket is off when car is off. You wont be charging anything.
Can you wire to battery terminals and plug in? Make sure it draws zero current if it is attached and not plugged into wall. Some chargers will kill a battery if not charging it.
10-21-2017, 09:07 AM | #4 |
RetNavSpook
67
Rep 398
It did work on the 2003 model. Are you saying it will not work on the 2016? The unit does not draw from the car but put into the car.
10-21-2017, 09:21 AM | #5 |
262
Rep 561
Drives: '23 M5 Comp
In newer BMWs the lighter socket is not powered when the car is not running. In the older models, it always had power so you could use it for the trickle charger to charge the battery. Now it is an open circuit when the car is not running, so plugging a trickle charger will not do anything. In the newer cars, it is recommended that you use the terminals under the hood rather than connecting directly to the battery in the trunk.
If you look at the battery terminals in the trunk you will notice that there are a number of wires connected to the battery. Not the simple two wires like in the older cars. |
10-23-2017, 01:26 PM | #6 |
Rep 18
https://no.co/products/charging/multipurpose
I highly recommend the line of smart chargers above. Some trickle chargers may cause the battery to "overcharge" and possibly degrade the integrity. I have use the G7200 frequently on my 71 240Z. I've also used it on my wife's 2008 135i for the repair feature on the original battery which was recently replaced. It certainly bought us some extra time before replacing it it August of this year. |
10-23-2017, 02:35 PM | #7 |
Beachtown Bill Collector
582
Rep 1,062
Drives: 2012 135i
Get a CTEK, and buy the pigtail that connects to the battery. CTEK is the original equipment trickle charger manufacturer for BMW, Porsche, GM, Ferrari, etc.
10-23-2017, 10:40 PM | #12 |
bimmerphile, technogeek
998
Rep 3,785
Drives: 2012 E82 6MT Sport
I bought an extension for my CTEK and routed it up near the passenger side wiper... That way, I don't have to open the hood when charging.
10-24-2017, 09:34 AM | #13 |
RetNavSpook
67
Rep 398
Can I just connect the CTEK to the car, using the under the hood connectors, and forget about it until I drive again? I just do not want the battery to drain, using all the on-board gadgets, when it is just sitting in the garage.
10-24-2017, 12:08 PM | #14 | |
998
Rep 3,785
10-26-2017, 10:34 AM | #15 |
27
Rep 91
Hi Folks,
I've never thought it was any trouble to pop the hood to hook up the battery tender. That way I can inspect the engine for any leaks, wipe off any dust and generally check things out. If I'm going to leave the charger on overnight I put a rag over the latch and lower the hood to relieve stress on the hydraulic struts that hold it up. Cheers! Craig |
10-26-2017, 08:46 PM | #16 |
Former Opel GT Pilot
327
Rep 771
Yes. You don't have to install a pigtail. You can use clamps to connect to the posts under the hood.
So, that's it. I am doomed. There is no patch, no methadone, no substitute. Curse you BMW. Curse you and your seamless power delivery. Curse the incredible sense of road feel. Curse the comfort, the luxury, the envious looks from the masses. I am... hopelessly addicted.
10-27-2017, 04:08 AM | #17 |
44
Rep 157
I attached the CTEk connectors directly to jump points, you can spread wires apart easily to get length and remove nuts on both locals to attach. Easily seen when you take a look lol.
10-27-2017, 04:00 PM | #18 |
Wolfsburg to Munich
75
Rep 294
Also a CTEK user here, you can actually sneak the plug through a space in the radiator support next to the PS headlight. Route the wire along the headlight edge and close the hood fully with the charger leads connected. I’ll take a pic if I have a chance.
10-27-2017, 05:59 PM | #19 |
1222
Rep 1,221
I just picked up a couple of these from Costco for $39.99 each. If you have a membership, it is a pretty good deal. They get great reviews on Costco.com and amazon.com.
https://www.costco.com/Battery-Tende...100241973.html |
11-02-2017, 03:45 PM | #20 | |
1222
Rep 1,221
Just got a flyer that Costco will have these on sale for $29.99. Pretty amazing deal at that price. |
04-01-2018, 09:25 PM | #21 |
27
Rep 239
Thanks for this!!!
Just did the same with my 1M and a Griots Battery Tender. I have looked right at this several times, but never hooked my charger up here, and kept hooking directly to the batter and tried to wedge the trunk open... TJ |
04-02-2018, 08:19 PM | #22 |
1543
Rep 3,071
More info please.
2011 135i w/ DCT | ZSP Sport Pkg | PPK | Ohlins R
chris_flies3027.00 |
