09-24-2017, 08:04 PM | #1 |
187
Rep 500
E92 M3 Shark Fender Air Vent (Opinion)
Need your opinion on the shark fender air vent on my E92 M3.
I made this and planning to put it on the fenders to give the M3 more aggressive looking in the front end. Option 1. Should I go wider/longer and more open vent (current has 4 with the same diameter)? Option 2. Should I keep it as is? Option 3. Don't even think about to put it on the M3? Last edited by M_GODZILLA; 09-24-2017 at 08:12 PM.. |
09-24-2017, 08:24 PM | #2 |
483
Rep 647
I would say option one could look good with molding it into the fender and not having it stick off the body. I would also say I wider would look good. If it's gonna stick out I wouldn't do it all.
09-24-2017, 09:32 PM | #3 |
11586
Rep 12,726
i like it, however, i would be afraid it wouldn't look as good once it is actually on.
is it just a plastic vent you bought off ebay for $10 and you are planning on bending it with a heat gun and molding it to your fender? if that is the case, i probably wouldn't do it.
Instagram; @roastbeefmike
09-24-2017, 10:01 PM | #5 |
11586
Rep 12,726
i bet with a little bit of work and finesse, you can make the side blinker gills functional if you're bored and want a project.
09-25-2017, 07:22 AM | #8 |
850
Rep 1,181
Drives: 2011 E92 M3 6MT ZCP
Option 3. Get some smoke colored reflectors instread.
09-25-2017, 11:43 AM | #10 |
1518
Rep 4,744
Drives: S65 1M Clone & E92 M3 4.6L
It's too small.
09-25-2017, 09:59 PM | #11 | |||||
187
Rep 500
Thanks guys,
This is not from eBay, it came off from a Porsche GT race car. I was plan to use 3D scanner and 3D scanner to make the sample first. However, I will look more into it and once again, thank you all for the commend. Quote:
10-14-2017, 02:14 PM | #14 |
338
Rep 923
If you're going for the same benefits as the fender vents that are on the GT3 RS then maybe go with the style similar as that car's vents? If you look at the front fender directly from the side then it probably easier for air to escape rearward instead from the top.
10-31-2017, 01:43 PM | #16 |
69
Rep 562
#3 hate it
TTFS Tune | DINAN Exhaust | Bimmerworld Xpipe | OHLINS Coilovers | Challenge Carbon Trunk | Eventuri Intake | APEX Wheels | AP Racing BBK | Turner Monoball
10-31-2017, 07:19 PM | #18 |
187
Rep 500
11-01-2017, 01:52 AM | #19 |
Lord Scrip
1813
Rep 3,013
Drives: 2011 M3 Coupe
Louver not vent
11-01-2017, 07:20 AM | #20 |
Rep 6
Something like this would be better in my opinion:-
http://n15design.com/product/n15-des...-fender-vents/ |
