      09-18-2017, 11:06 PM   #1
jasera94
Drives: 135i
135i | N54 |diagnosing misfire
Hi Team,
I've recently picked up my first Bemmer an 08 135i Manual with 70,000 kms on the clock completely stock standard.
It starts and goes mint until a sudden hard acceleration. slowly planting the acceleration is fine but in sudden acceleration the car thudds/ jerks and goes into limp mode. bringing a p0305 code. this does not aaalways happen.
To me it seems if it was a coil and/or Spark plugs the car would always be in a rough start/ limp mode / be doing it more often.. yes? No?
(new Vanos + Plugs on the way but..)
would this rather be the injectors not being able to supply the fuel and going bad?
My real question is if it is the Injectors and I take it to a shop.. how will they know what needs done without someone having to take my car for a drive and thrashing it to get the symptoms and the codes to fix the issue?? (I have trust issues)
Also if i take it to BMW (NZ) will they replace because it was an issue prior or would i need to claim on my warranty insurance?
Thanks team!
      09-23-2017, 09:19 PM   #2
AB M2C
74
Drives: 2019 M2C Hockenheim Silver
Originally Posted by jasera94 View Post
Hi Team,
Thanks team!
Could be an injector, but I have some doubts. Generally on these cars when the injectors go bad they leak while just sitting there, but provide adequate fueling while running. You didn't get the other associated codes but the other thing it could be would be your HPFP.
Current -- 2019 M2C MT
Sold -- 2009 E82 135i MT Widebody Track Car
Sold -- 1989 E30 325i MT Showcar
Sold -- 2005 E46 M3 MT
      09-26-2017, 02:42 PM   #3
HawkeyeGeoff
HawkeyeGeoff's Avatar
Drives: E90 335XI MSport, S2000
I'd just start with all coil packs + sparks. I'd put money on it not being done at that mileage.
Once you do that then all that is left is injectors or compression of the motor.
      10-01-2017, 05:32 PM   #4
jasera94
Drives: 135i
I Checked the Injector Version numbers yesterday... cylinder 6 & 5 have version 5 Injectors and 4 - 6 are Version 9...
      10-03-2017, 08:07 AM   #5
HawkeyeGeoff
That doesn't tell you much other than they're old.
      10-16-2017, 08:44 PM   #6
jasera94
Drives: 135i
Hi Team,
Decided id do the walnut blast while changing spark plugs and noticed cylinders 1-4 are just all black dirty usual carbon build up but cylinders 5 & 6 have a sort of clean patch in-between the valves? still dirty but not the same as the rest...
