KEEP M3POST ALIVE BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER LINK! |
09-02-2017, 10:37 AM | #1 |
4452
Rep 4,014
ZCP powder coated wheel issues
I have OEM 359 wheels that were powder coated by a previous owner. The clear coat has worn away in areas and is peeling. My question is if I decide to not have them re-powder coated, can I just remove the old coating and have the wheels taken back down to the stock silver? Is anyone aware of a DIY for removing wheel coatings?
09-02-2017, 10:45 AM | #2 |
F15 daddymobile
2352
Rep 3,510
the oem finish was stripped to apply the powdercoaing that is currently on the wheels. if you remove the peeling powdercoating it will be bare metal underneath
you will need to chemically strip the powdercoating and have it recoated |
BOOF-M34451.50 |
09-02-2017, 03:54 PM | #3 | |
4452
Rep 4,014
Also, I have CF side mirrors. The clear coat has peeled off of half of one of the mirrors. I did speak to my paint guy but he didn't have any experience with clear coating over CF covers. He was worried about doing any type of sanding on the mirror and affecting the CF pattern. Any ideas on the wheels and mirror? Thank you. |
09-03-2017, 05:04 PM | #4 | |
F15 daddymobile
2352
Rep 3,510
Can you feel the weave on the mirror, or is the epoxy still in good shape and just the clear is peeling? If the latter, then you could use a scotchbrite pad and rub where the peeling area meets good clear. Do that very carefully. Then re-clear the entire mirror with a few coats.
09-03-2017, 08:34 PM | #5 |
11586
Rep 12,728
i'm no coating expert, but if two of those wheels are going like that- the rest will soon follow. take them to a quality wheel refinisher.
i think you're better off just buying new mirrors than investing money into them.
Instagram; @roastbeefmike
BOOF-M34451.50 |
09-03-2017, 10:06 PM | #6 | |
Stop the hate, get a V8
3851
Rep 8,625
Any reputable shop isn't going to try and coat on top of someone else's shitty work. To do it right, they'll strip the wheel down and redo the whole thing. Be aware that the factory ZCP wheels are not silver, they are hypersilver. If you have them refinished in silver, they will not look the same. Hypersilver requires a multi-layer process. My wheel refinishing shop warned me about this and said it's why they recommend having both wheels on the same side of the car refinished at the same time -- replicating the OEM hypersilver is difficult.
Now: 2017 Corvette Grand Sport, 2021 AMG C63 S sedan
Past: 2011.5 M3 sedan ZCP |
BOOF-M34451.50 |
09-03-2017, 10:46 PM | #7 | ||
4452
Rep 4,014
For the mirror only the clear coat is peeling. Yea my paint guy was a little worried about the weave in the event that he scratches through while only trying to eliminate the pealing clear coat. I believe you are correct, it can be done. Thank you Shimmy. |
09-03-2017, 10:48 PM | #8 | |
4452
Rep 4,014
One mirror is perfect. The other it's only the clear coat peeling, the CF underneath is perfect also. The only problem is I'm seeing different pricing for the mirror caps. I don't know if this is a $140 set or a $300 set. Would rather spend a few dollars having the one side redone if possible. As opposed to paying $150 for one CF mirror cap. |
09-03-2017, 10:49 PM | #9 | ||
4452
Rep 4,014
09-06-2017, 12:22 AM | #11 | |
3851
Rep 8,625
What did you use? After two of my ZCP wheels were redone, I kept using the same stuff I always had (Sonax), but I also used regular car wash soap and Iron-X without any problems. Powdercoating is quite resilient but it isn't impenetrable. Sounds like your powdercoater did a crappy job or you used a really harsh solvent.
09-06-2017, 09:40 AM | #13 | |
947
Rep 1,933
Drives: 2013 E92 M3
BOOF-M34451.50 |
09-06-2017, 09:44 AM | #14 | ||
4452
Rep 4,014
UPSROD947.00 |
11-09-2018, 05:43 AM | #15 |
4452
Rep 4,014
Not sure why I didn't finish this thread off with a final outcome. I found a local powder coating shop https://www.abpowdercoating.net/. These guys were professional and did exactly what they said they would do. Once I dropped off the wheels they took them to a local tire shop and had the tires and TPMS removed. They then stripped off the old powder coating and redid them in a smoked finish similar to what they had been. Tires and TPMS were then put back on and balanced. Total cost was $300 ($75 per wheel) and add $50 for the tire shop. What a great experience and the wheels came out perfect.
For the CF mirror cap I went to a local paint and body shop. I had some peeling/bubbling on my CF gloss side markers also. Total charge to re clear coat the one OEM mirror cap and the two side markers $50. All came out perfect. There is no way to tell that either have been redone. I'll add some photos later today. |
11-12-2018, 03:30 PM | #16 |
143
Rep 213
Pics? I have some comp wheels waiting to be fixed up and need them refinished as well so trying to decide myself which route to take (color/process, paint or powder coat). Curious how yours look now and which color you went with, you mentioned you powder coated them "smoked finish" specifically which color code or special finish? I thought powder coating wasn't able to replicate a multi stage paint process in order to match the OEM wheel look/'depth' that a multi step paint job would require.
