08-24-2017, 09:49 AM | #1 |
58
Rep 526
Best and Cheapest Battery for 128i
Guys,
My car died on me in the middle of the city and it's time to get a new battery. What is the best AGM (I am assuming is the best type) of battery to get and where can i find it? I found this one at my local store. I would like to purchase a battery and get it coded at my local coder. https://www.pepboys.com/product/deta...03.0L%2520DOHC * I bought the battery in the link above and had it registered at a local BMW/Mini race shop for $81.00 (Tax Incl) Last edited by bazil769; 08-25-2017 at 06:37 PM.. |
08-24-2017, 12:53 PM | #2 |
170
Rep 615
The one you have linked seems to be a good one. And download INPA if you have a windows laptop and code it yourself. There are lots of DIYs out there. Also if you have MHD I'm pretty sure you can register the battery from that app.
08-24-2017, 01:03 PM | #3 |
912
Rep 1,850
"Best" is a meaningless term without clarification:
--maybe you want the lightest battery, in which case you would use a couple lbs of high discharge lithium --maybe you need tons of capacity to run your hydraulics, so you have a huge 300lb battery bank in the car --maybe you want an easy battery to buy and install, which could be a cheap generic lead acid from walmart --or maybe you're on a serious budget, in which case the "best" battery is the one you swap out of your friend's pickup that sits in his driveway for free --maybe you want the longest lasting battery, which would be lithium and expensive |
08-24-2017, 01:38 PM | #4 | |
58
Rep 526
08-24-2017, 01:39 PM | #5 |
58
Rep 526
Can you post a diy link using the INPA software and necessary hardware? Will the MHD app work with the N52 engine?
08-24-2017, 08:16 PM | #7 |
912
Rep 1,850
For MHD I doubt you need a DIY the app is pretty self explanatory. Just put your device in airplane mode, connect it to the car, open MHD, and go thru the menus until you find the register battery option.
08-25-2017, 12:53 AM | #8 |
170
Rep 615
08-25-2017, 10:53 AM | #9 |
58
Rep 526
Ok. I got the software. Now I have to get the cable. Is the process to use the AGM battery the same as using the original battery. Or will the software have an option to switch the ecu to use it? Any recommendations on where to get the best cable?
08-25-2017, 02:46 PM | #10 |
815
Rep 1,078
Drives: Lots of BMWs
Garage List 2018 M4 Vert [0.00]
2006 Z4M Roadster [0.00] 1995 540i [0.00] 2008 BMW M5 [0.00] 2019 i3 Rex [0.00] 2021 X7 40i MSport [0.00] |
I use a bluetooth module with other software. Either way bluetooth or cable, Amazon is best
2008 M5 6spd, 1995 540i 6spd
2018 M4 Vert Comp, 2019 i3 120ah REX 2021 X7 40i MSport, 2006 Z4M 6spd |
08-25-2017, 02:51 PM | #11 |
Driven Crazy
190
Rep 505
There are two or three battery manufacturers in the US. There are hundreds of battery brands. You do the math.
'08 128i 6M
08-25-2017, 06:35 PM | #12 |
58
Rep 526
08-25-2017, 06:35 PM | #13 |
58
Rep 526
08-27-2017, 12:53 PM | #15 | |
816
Rep 1,199
