08-09-2017, 11:57 PM | #1 |
9
Rep 50
FS: 1998 BMW E36 Alpine White M3 Turbo: Show and Collector, spare motor etc
Helping out a buddy out, the car is as clean as advertised. Asking $35k for car + spare built motor and other compents I am putting this feeler out for my Alpine White/Mulberry 1998 E36 M3 Turbo as I feel its' time to move on to another project. I am the 2nd owner (1st also in CA) with the car currently sitting at 43k original miles. Along with the extensive mod list below, I'd like to sell as a package along with my previously planned 'part 2' for the car which includes a spare fully built motor, Euro 6 speed transmission, and 210mm drive shaft. These components alone run ~$15k. The car does have it's tiny flaws for being almost 20 years old, however it's as clean as it can be as I have meticulously maintained it through-out my ownership. It has just been cover featured in Performance BMW Magazine, July 2017 issue. As this is just a high-level feeler, all details may not be included in the description, but serious potential buyers feel free to inquire. Reminder - I am NOT parting out nor will I take reservations to part, please do not ask. Also, not accepting any trades. **Please excuse photo quality. Full documentation along with quality photos can be seen via IG account: @re36tro **Technical data (motor): Dyno'd at 610whp/571rwtq Cut Ring 87mm head gasket (stock compression) ARP2000 head studs Garrett GT3528R Dual ball bearing Turbo SPA T3 Turbo Manifold 24x12x3 Front mount intercooler Tial 50mm Blow-off valve Tial 44mm MVR wastegate Turbosmart Eboost2 boost controller M50 intake manifold Mishimoto coolant overflow Mishimoto performance aluminum radiator Steward high performance water pump RK Tunes E85 Turbo tune and Mass Airflow Sensor 115lb high impedance injectors Rally Road high flow billet fuel rail Aeromotive adjustable fuel pressure regulator Vibrant intake filter Custom fabricated 3" stainless steel down pipe and exhaust system Vibrant turbo muffler Radium Engineering oil catch can Radium Engineering 12 micron fuel filter Racetronix Fuel Pump wiring harness Walbro 485lph fuel pump **Transmission: BMW 5spd ZF transmission UUC Twin Disc Flywheel clutch UUC Steel clutch line Rally Road clutch pivot pin UUC EVO3 short shifter with Double Shear Selector Rod **Chassis: Bilstein PSS9 coilovers Vorshlag polyurethane engine mounts Vorshlag polyurethane transmission mounts Dinan front strut tower bar Dinan rear strut tower bar BMW OEM X-Brace BBS LM Wheels 18x8.5 Front, 18x9.5 Rear BBS Red center caps BBS lug nut conversion Front tires: Hankook Ventus V12 evo2 235/40 Rear tires: Toyo Proxes R888 255/35 (> 100 miles) Brembo GT Big Brake Kit, 355x32/328x28 2 piece rotors Hawk HPS brake pads **Exterior: ZKW HID projector headlights ECS tuning European front clear corners ECS tuning European side markets ECS turning European rear tail lights Max Velocity RS front lip Mateo Motorsports rear diffuser UUC 3 way adjustable carbon fiber spoiler **Interior: Custom wrapped European 3 spoke steering wheel MT shift boots Alcantara shift boot MT shift boots Alcantara Emergency brake boot Rally Road steering column dual gauge pod LeatherZ center gauge pod Turbosmart Eboost2 boost controller/gauge Zeitronix ZR-2 Wideband Air Fuel Ratio gauge Zeitronix ECA-2 Ethenol Content Analyzer gauge Zeitronix ZR-2 Boost gauge Zeitronix ZR-2 Fuel Pressure gauge **Parts to continue project: BMW Large case LSD 210mm 3.15 Differential E36 M3 Euro 6 speed transmission with 47k miles (new seals included) UUC 96-99 Euro 6 Speed EVO3 Short shifter with carrier and DSSR109 **Fully built motor capable of 1000hp Machined head, Bore & Hone Cutring 86mm Supertech valves, valve springs, retainers Carillo rods w/ CARR bolts CP-Carillo Pistons 10:5 compression ratio, 85.5mm w/ CP HP wrist pins Calico Rod and main bearings Achilles upgraded oil pump and upgraded oil pickup tube S52 Vanos ARP Main Studs ARP Head Studs ATI Damper M52 block S52 Polished Crank S52 cams and tray ECS Tuning Aluminum Water pump pully Thermostat - 71 degree EMP/Stewart High Performance Water Pump Includes new engine stand http://www.m3forum.net/m3forum/showthread.php?t=590931 |
