08-05-2017, 09:20 PM | #1 |
Rep 18
Custom built wheel spec question
Since we do not have many options for 1 piece wheels I want to get some made. Going with Forgestar M14. 18x8.5 front 18x9.5 for the rear. My question is this..... what is the "BEST" offset for both front and rear? 225/40 front tires, 255/35 rears..... Car is lowered on Cobb springs (same as Eibach Sport).... I want to avoid running spacers and want the best fitment without any rubbing issues. I do not want to roll my fenders. Thanks
Here is the wheel! Not sure on color combo yet |
08-06-2017, 11:31 AM | #2 |
121
Rep 2,037
Drives: 2008 135 blk, blk, step
Garage List 1994 Porsche 968 Cab [0.00]
2017 AMG GTS [0.00] 1994 Porsche 968 Coupe [0.00] 1977 Mercedes 450SE ... [0.00] 2008 135 [8.00] |
I'd definitely go with et42 up front. Rear is more complex. With a 9.5inch wheel, you could go really high before you'd run into the inner fender, like et62. But for best looks was far as how they stick out vs the front, et48 or so should be about right. If you want to play it safer, you could go a tad higher. Also, I'd try to find out what rear et might effect how concave the wheel will appear.
Injen, RR OCC, MadDad Whisper, donut spare, 19x8.5et43fr 19x9.5et45r Volk LE37's, rear fenders rolled/pulled, PSS4S 225/35fr 255/30r, KW V1's, AR coated catless dps, Cross strutbar, CF grills and license plate holder, iCarbon diffuser, ETS black anodized FMIC, M3 control arms, Quaife, ER chargepipe, ForgeDV's, Topspeed Custom Tune, V3sims, Braille, Andrey_GTA rear hub mod, Ebay Mstyle front bumper and performance style side skirts.
08-06-2017, 02:58 PM | #3 |
13523
Rep 8,165
FWIW, Apex wheels are 18x8.5 ET45 & 18x9.5 ET58 and that is a proven setup...
BBS USA have recently added RI-A wheels on their website, which were previously only available in Japan I think. On the Japan website, they have a 1er-specific setup - 18x8 ET45 & 18x9 ET50. They are forged one-piece monoblocks. Most likely not cheap but I don't know how much your custom Forgestars would cost. http://bbs-japan.co.jp/en/products/1135/ http://www.bbs-usa.com/race_wheels/w....cfm?wheel=116
10-16-2017, 09:31 PM | #5 |
119
Rep 1,525
What about 18x8.5 et35 and 18x9.5 et40 I don't want run negative camber but I will roll or shave the fenders if i have to
2008 335i FFTEC ST 6266,), Boostbox, VRSF 3.5 exhaust, mtech front and rear, KWVll, APEX 18x9.0, 18x12= 305/35/18 NTO1s, BMS OCC, Rb PVC, M3 tri-color stitched S-wheel,MT SWAPPED, M3 LSD diff
2008 135i mods coming soon! |
10-16-2017, 10:26 PM | #6 | |
232
Rep 2,643
Possibly you can make lower offsets work if you are into custom fitments, but unlikely to be as fully functional as having the correct offset that is intended for the car. |
10-19-2017, 01:02 PM | #7 |
223
Rep 542
+1 for ET58 being perfect for the rear for a 9.5" wheel. Apex made this offset specifically for our cars, you can fit a 275 on there without any issues, no way you can do that with ET40 (I couldn't even fit a 255 without rubbing on my rolled/trimmed/slightly pulled rear fenders!)
10-23-2017, 08:07 PM | #8 |
119
Rep 1,525
yeah but what about wheel gap that looks disgusting
