07-18-2017, 08:31 PM | #1 |
32
Rep 256
Will these wheels/tyres fit?
Hi Guys
Can someone pls tell me if the below will fit without rubbing? My E88 135i (MSport) is stock....i've got no idea when it comes to offsets etc... Fronts 18x 8.5 ET29 with 245/40/18 tyres Rears 18x 9.5 ET23 with 265/40/18 tyres 5x120 pcd Thanks
[2011 E92 M3 Jerez Black]
evolve stage II | alpine dct & mdm | resonated test pipes | rays forged G25 | vorsteiner gts-v front lip | metak rear diffuser | awron gauge |
07-18-2017, 10:42 PM | #2 |
14
Rep 36
Not even close
07-19-2017, 01:31 AM | #3 |
32
Rep 256
07-19-2017, 10:02 AM | #4 |
Rep 43
High-jacking because I have similar questions, 2011 stock m-sport. I was looking at these wheels, I'm sure a couple other owners have them Apex ARC-8
https://www.apexraceparts.com/wheels...eel_diameter=5 But I'm unsure which offset to go for, less is closer to stock correct? What offset do I want to get these to fit on stock m-sport suspension? If I went: 18/8.5 18/9.5 Which is what comes stock on the car, and went with similar tire sizes/widths. |
07-19-2017, 11:10 AM | #5 | |
545
Rep 1,233
Front: 18x8.5" ET45 APEX ARC-8 Wheel Rear: 18x9.5" ET58 APEX ARC-8 Wheel FYI Stock offset/sizing is: 18x7.5 ET49 (front) 18x8.5 ET52 (rear) Use this link to compare how far the wheel/tire moves in or out: http://www.willtheyfit.com/ Last edited by asbrr; 07-19-2017 at 12:08 PM.. Reason: fixed error |
07-20-2017, 02:10 PM | #9 |
Rep 36
High-jacking because I have similar questions, 2012 e82 100% stock (Msport)
I bought in the group buy some apex arc-8 Front: 18x8.5" ET45 APEX ARC-8 Wheel Rear: 18x9.5" ET58 APEX ARC-8 Wheel According the Apex sale man, 235/40 front and 265/35 rear should fit fine I bought some Yokohama Neova ad08 265/35 for the rear and they are a little wider that a normal 265/35 Will they fit without any rubbing? Thanks! Greetings from Argentina! |
07-20-2017, 04:19 PM | #10 | |
545
Rep 1,233
