07-13-2017, 08:32 PM | #1 |
Rep 24
Will 2011 328xi wheels fit my 135i?
Hey all,
I'm doing some early searching for some winter wheels and found some 17"s from a 2011 328xi. I haven't had much luck googling which Style # and the offset. Anyone know if these will fit my 2011 135i? Thank you in advance! |
07-13-2017, 10:35 PM | #4 |
Rep 24
07-15-2017, 10:05 PM | #5 |
17
Rep 45
Drives: a superior vehicle
sorry for the bump in advance.
they probably will fit,they'll just be a bit on the aggressive side. if you're looking into OEM looking wheels,my cousin bought style 107 wheels off of a BMW Z4 for his 128i. ET 47 front,ET 50 rear. |
UB2SLOW6.00 |
07-16-2017, 06:32 AM | #6 |
1542
Rep 3,071
This site might help with identifying which wheels & offset. I don't believe 328 wheels will work b/c such low offset. Recommended set up to avoid rubbing is typically ET45-47 front & ET45-58 rear. Some have made lower offset work but it depends on your willingness to mod, change the front camber or roll the fenders.
http://www.bmwstylewheels.com
2011 135i w/ DCT | ZSP Sport Pkg | PPK | Ohlins R
UB2SLOW6.00 |
07-16-2017, 10:15 AM | #7 |
96
Rep 406
Drives: S54/N52
I am currently running 17x8 ET40 fronts and ET35 in the rear with 225/45s.
I have no issues with rubbing even on big dips. However I would be weary of ET34s up front unless you have some cambers blended into it. |
UB2SLOW6.00 |
