07-02-2017, 02:40 PM | #1 |
629
Rep 1,753
Looking for a good aggressive street pad
After going thru 2 pad/rotor warranty claims, I am tired of dealing with the bad mesh between the stock pads and rotors which cause vibrations if used aggressively on the street (i.e. Mountain roads/canyon carving)
I'm content with the stock rotors so I don't want to go full on BBK, I just want some good performance street pads that don't sound like a school bus. Is there anything on the market in stock caliper sizes that are as good , if not better, for stopping power and initial bite?? I seem to see a lot of options for track pads, but not "street performance". There has to be a better material out there that works better with the stock rotors.
18? Camaro 2SS 1LE
16' M3 MG Ext. /SO Int. (DCT, Ohlin R/T, 19" wheels) 15' Audi S4 13' Audi TTRS (APR stage 1, MSS springs) 09' C6 Z06 08' M3 Interlagos Blue: 6sp, Tech. |
07-04-2017, 08:26 AM | #3 |
209
Rep 353
Another vote for the R4S pads. I haven't noticed and loss of initial bite but I replaced my brake lines with stainless steel lines when I did the pad swap and that may be why.
07-05-2017, 12:45 AM | #5 |
629
Rep 1,753
WTH does that have anything to do with rotor/pad meshing???
Put down the crack pipe
18? Camaro 2SS 1LE
07-05-2017, 01:16 PM | #6 |
310
Rep 408
/crack pipe down
DSC will intervene in 2 ways: Apply selective braking (typically to 1 corner) Cut throttle Application of braking by the DSC system could lead to excessive heat in your brakes. Application of selective braking is only really noticeable by the flashing DSC symbol on the dash. The throttle cut is impossible to miss. You can easily be causing DSC braking without realizing it. /crack pipe back in hand |
Fake News 2017335.50 |
07-06-2017, 11:49 AM | #7 | |
629
Rep 1,753
It happens with normal commute driving as well. The pad material used and the rotor material just don't mesh well. There has to be a good intermediate pad somewhere in-between street and track out there
18? Camaro 2SS 1LE
07-07-2017, 07:40 AM | #10 | |
310
Rep 408
They stated they think they are having issues with overheating brakes because of faster driving sessions. A possible cause for this is DSC intervention. |
07-07-2017, 11:39 AM | #11 | ||
629
Rep 1,753
18? Camaro 2SS 1LE
ccondo160.50 |
07-07-2017, 12:36 PM | #12 |
368
Rep 697
Carbotech bobcat* or XP8 would be my recommendation.
07-07-2017, 12:52 PM | #13 | |||
HMFIC
336
Rep 568
07-07-2017, 05:17 PM | #14 | |
629
Rep 1,753
Once they are cool, they are smooth again. That is why I say the pad material doesn't mesh well with the rotors. It only takes a few spirited braking sessions to make it happen too, so it happens pretty quickly if you are getting deep into the brakes. I can repeat this daily without fail just with my morning commute. Brakes start off smooth, get a couple decent quick stops on the freeway (typical in bay area traffic) and the vibrations start up. Leave work, smooth brakes, a couple of quick stops from 60+, vibrations. You get the point. Warped rotors, it would be consistent. Pad deposits, it would be consistent. The only logic explanation is the pad material is too soft and doesn't play well with the rotors with any sort of heat. I had a E90 M3 and had no such issues.
18? Camaro 2SS 1LE
16' M3 MG Ext. /SO Int. (DCT, Ohlin R/T, 19" wheels) 15' Audi S4 13' Audi TTRS (APR stage 1, MSS springs) 09' C6 Z06 08' M3 Interlagos Blue: 6sp, Tech. Last edited by TRZ06; 07-07-2017 at 05:24 PM.. |
07-07-2017, 05:47 PM | #15 |
629
Rep 1,753
The Carbotech 1521 sounds interesting looking on their website. The XP8 sounds interesting as well.
I do not track, but I do canyon carve sometimes. This is my daily and in stop and go traffic, so I do want something quiet with good initial bite and just a bit better overall biting power than stock.
18? Camaro 2SS 1LE
07-07-2017, 09:01 PM | #16 | |
2251
Rep 5,683
I would not recommend using any CT XP compound on the street unless you enjoy loud squealing and a lot of dust! However, their performance is awesome. |
07-07-2017, 09:15 PM | #17 |
62
Rep 196
