06-15-2017, 12:55 PM | #1 |
42
Rep 69
Brake pad and alignment schedule...
Every time I go into the dealership for service they've been telling me that I need to do alignment. The first time they said the alignment is off and I shall do it, second and third time they didn't say anything and told me that it's recommended I get alignment done every 20000KMs. I refused this time.
I'm currently at 38000KMs, if I did my alignment yesterday it would have been the third alignments.. WTF. Another question regarding the brake, so I'm currently at 38000KMs and the service menu is saying that I need rear brake pad replaced in 5000KMs and 15000KMs for front brake pad... I would have thought the front one would go first ... is this information based on a sensor or it was adjusted by my dealership or it's BMW's schedule. Thx |
06-15-2017, 01:51 PM | #2 |
462
Rep 494
I only get an alignment done if I notice one of these symptoms:
- the car does not run straight - the steering wheel is not perfectly centered - any front tire has an uneven wear on the inner or outer part of the thread. Before deciding about an alignment I check the tire pressures, all four. Avoid unnecessary alignments - even on good aligning benches a careless or untrained operator can leave your car in worse shape. |
06-16-2017, 11:04 AM | #3 |
290
Rep 1,547
^^^ Agree with the above. Only reason I aligned mine, is I lowered it. As for the brakes, just reset the reminder via the cluster...its very easy to do. The pad sensors do not measure thickness. They serve as a fail safe should the pads wear down to a certain point.
2014 BMW X5 xDrive 35d M Sport Mineral White
2011 BMW 135i M Sport Space Grey 2007 Suzuki GSX-R 750 |
