06-15-2017, 10:40 AM | #1 |
118
Rep 392
LED Halo Brightness Coding Question
Creating another thread for future searching purposes
Anyways, none of the cheat codes for brighter halos are for LED's I did some digging when coding off my amber side LED's See pic below, is the 9th Werte value in related to the Halo brightness? I see it at 64 now, will changing it to 100 in Standicht Modus 1 & 2 for LHM 43 & 43 make my Halos for LED @ 100% all the time? Figured I would ask before I code. Also not sure if any changes are needed in FEM_BODY, I would rather understand how to change this manually than use a cheat code. Thanks in advance! |
06-15-2017, 11:28 PM | #2 | |
2376
Rep 8,364
krotondo118.00 |
06-16-2017, 08:26 AM | #3 | |
118
Rep 392
09-07-2017, 01:35 AM | #4 |
233
Rep 1,276
A couple questions:
1. For LED headlights, were you able to disable amber sidemarkers? 2. For LED headlights, were you able to increase the Angel Brightness to 100% with low beams on?
2018 F80 M3 AW / SO
09-07-2017, 02:25 AM | #5 |
2376
Rep 8,364
In every car I have coded, this is possible. Though, 100% gives a washed out look that is also glaring to other drivers and I would advise against; instead, try 60%.
09-07-2017, 12:38 PM | #7 |
2376
Rep 8,364
Correct. Though, confusing part for FLE's is that Group 3004 number references 3005 behavior. As such, you do not directly set to 3C in 3004.
09-07-2017, 03:32 PM | #8 | |
233
Rep 1,276
Compare Tagfahrlicht (DRL) to Standlicht Modus 1/2 (low beams/driving) to find the correct value to edit?
2018 F80 M3 AW / SO
09-07-2017, 03:36 PM | #9 |
2376
Rep 8,364
Incorrect. That is what you do for TMS. For '18 with FLE, it is DRL_Idx to POL1/2/3_Idx. And, as stated, you cannot directly change just werte value there to desired intensity as those 3004 wertes are references for 3005 values.
09-07-2017, 03:37 PM | #10 |
233
Rep 1,276
Another question sorry...in another thread regarding disabling amber sidemarkers with LED headlights, I got these instructions to code the TMS as per below.
For an '18, will I be doing exactly the same, but with the FLE instead? -- Instructions -- For LED headlamps: You'll need to FDL code both TMS modules (one is for the left light, one is for the right) Within TMS, search for Standlicht Modus 1 & Standlicht Modus 2, and change the Werte Value 64 to 00 as follows: Original: 00, 03, 00, 00, 64, 03, 00, 00, 64, 03, 00, 00, 2B, 04, 00, 00 Change: 00, 03, 00, 00, 00, 03, 00, 00, 64, 03, 00, 00, 2B, 04, 00, 00
2018 F80 M3 AW / SO
09-07-2017, 03:46 PM | #11 | |
2376
Rep 8,364
Plus, with TMS, you can directly change 64 (100%) to desired level (eg, 3C for 60%). It is not as simple for FLE. This is for my F015:
09-07-2017, 03:56 PM | #12 | |
2376
Rep 8,364
johnerod7531.50 |
03-28-2024, 01:37 AM | #13 |
Rep 2
Hi
I hv G30 adaptive led headlights. I wish to reduce intensity of my front led drls to 20% only while headlights on or off. Can you pl guide, which parameters i need to change in FLE or any other module. Also I wish have tail lights as drl. How to code? Thank you Abhay gujar |
