      05-24-2017, 06:01 PM   #1
Jomammaa
Drives: 2013 135i m-sport
Nitto NT01's
So, my apex wheels should be here this friday. I'm looking to get a set of nitto nt01s.
I was planning on getting 235/40/18 for the front and 265/40/18 on the rear however, Im starting to have second thoughts about fitment.
The car is a stock e82 m-sport.
Anybody have experience with this set up?
      05-24-2017, 08:59 PM   #2
1and1
Loves me some MHD!
1and1's Avatar
Drives: faster than he should...
'09 135i  [10.00]
Rear +1 is 255/35-18, so if you want 265 you may well want to go for a shorter sidewall, like a 265/35, or 265/30 even, if you want the overall diameter to be close and speedo to be sort of accurate...
1and1
135i - E82.N54 2009 BSM - MHD / xHP / DCI, PR CP & 7.5" Race IC / N55 mid & Borla
. . WL RSFI, Koni, Eibach & Dinan CP's, M3 CA's / EBC Red's & Firehawk 500's
X1 - E84.N20 2013 MGM - JB4 - The Wife's, now with new turbo & ewg
      05-25-2017, 06:00 AM   #3
Jomammaa
Speedometer reading isn't much of a concern. I'm pretty much only going to use these at the track.
What do you mean if I want 25? Also these tires don't come in those sizes.
      05-25-2017, 06:27 AM   #4
1and1
Loves me some MHD!
1and1's Avatar
'09 135i  [10.00]
was supposed to be 265, not 25, and totally spaced that you were asking about NT01's despite you clearly saying it several times- just me being worthless
1and1
      05-25-2017, 05:33 PM   #5
Jomammaa
I appreciate the reply regardless
      05-25-2017, 08:07 PM   #6
derekh
Drives: ---
Don't know about fitment on the 1ers but i had a set of nt01 for my golf. They are well worth the money. I have a hard time believing they will cause you issues there are lots of guys that run 275s.
      05-26-2017, 01:59 AM   #7
Nasserdamus
16
Drives: 09 135i / 01 Z3 M Coupe
265/35
Slight rubbing on hard bumps ect, I'm running ps91 and no issues. These are from the recent group buy. A fender roll would help, doesn't happen daily.
Stock suspension
FBO obviously
      05-26-2017, 05:46 AM   #8
Jomammaa
Where are you rubbing?
      05-26-2017, 08:29 AM   #9
HawkeyeGeoff
HawkeyeGeoff's Avatar
Drives: E90 335XI MSport, S2000
Oh.... you know
Appreciate 2
      05-26-2017, 08:40 AM   #10
ShocknAwe
1Addict
ShocknAwe's Avatar
3234
Drives: E82 Mutt, M57 Truck
NT01/05 run taller than most tires. I would definitely go one step down on sidewall ratio. So on a 18" I would spec 235/35 and 265/30.
2010 135i 6MT Jet Black
N54/3 FE82 Mutt | BUILD THREAD | GARAGE SALE
      05-26-2017, 07:13 PM   #11
Jomammaa
I really want these tires now im not sure if I wanna do 275/35 instead, which will probably be too wide
      05-26-2017, 07:56 PM   #12
ShocknAwe
1Addict
ShocknAwe's Avatar
3234
Might want to start measuring how much room you have and talk to a body shop about modifying the rear fender.
Curious, why do you think you need that much tire?
      05-27-2017, 01:48 PM   #13
Jomammaa
I want nitto's, which don't really come in the sizes I would like. So I'd rather go oversized rather than undersize for the track.
      05-28-2017, 06:50 AM   #14
YarkoDrives
10
Drives: 135is 98FS, 128i, 335xi,
Be careful with the taller height tire-- It can grab the front vertical edge of the rear fender!
The NT-01 265/40/18 is 26.3" tall, a little shorter than my test, but 20mm wider than the tire I was fitting. If you are running ET60 then the tire might tuck in ok.
I tried fitting a taller diameter tire on the rear of the e82.
RE-71 245/45/18 which has 26.7" diameter on an ET48 wheel.
Suspension is OEM BMW Performance Springs. -1.8 deg camber.
Did a short test drive under 45mph.
The tire grabbed the front edge of the fender when under load on a merge ramp.
This damage to the fender was just 2 seconds at 40mph. A consecutive hit would likely have cut the tire as the fender was getting pulled into the tire.
I'm suspecting the 245/45/18 may fit at ET 52. I'll be doing a clearance test with the rear spring removed before I try driving on them.
      06-02-2017, 03:13 AM   #15
Nasserdamus
16
Outter tire wall, taken care of with a fender roll.
FBO obviously
      06-02-2017, 12:10 PM   #16
Jomammaa
Front or rear?
      06-02-2017, 09:03 PM   #17
Nasserdamus
16
Front or rear?
sorry for not clarifying, but my front was scrapping.
Basically hit a bump and it left a bulge on the fender lip inside and left a mark on my tire wall. Not a big deal, but i do suggest if your running 235 in the front on stock suspension roll your fenders. If you want to try to run 245+ you will need camber plates and negative camber, We have pretty f'd up highways in socal and my 1er is my daily, Once i rolled it no issues at all. I have heard some people scrape on 265 rear but ive never noticed a thing, but then again im not running nt01, using ps91.
FBO obviously
      11-02-2017, 12:27 AM   #18
jradon
18
Drives: 2series
Just curious if these Nitto NT01 tires will work fine on the street. I know they will wear faster, but how about their performance on dry and wet roads?
      11-02-2017, 09:31 AM   #19
tsk94
tsk94's Avatar
1522
Drives: E92 M3, E82 128i, F82 M4, E36
They'll work.. They are VERY noisy and that can get a bit tiresome. Wet perform is good for what they are, when full tread. With that being said they aren't nearly as good in wet conditions when compared to Extreme performance summers tires, let alone a max performance summer tire.
I think you'd be better off investing in a 2nd set of wheels and mount the NT01's on them for track use and get yourself some 'regular' summer tires for everyday use. They'll wear out so quick when used daily that I wouldn't recommend it.
With that being said I've been very happy with the NT01's for track use. They aren't the stickiest tire out there, R1's or Hoosiers are definitely a big step up. However, the Nitto's have much better wet perform when they have tread, wear well and are still perform great even when they get very low (basically good till they cord).
      11-15-2017, 07:24 PM   #20
jradon
18
Drives: 2series
I will just use my car once in a while since I have a truck as my DD.
      11-16-2017, 07:54 AM   #21
HawkeyeGeoff
Get some RE71R and be done with it. NT01 are great...but they really are old technology. You can run them on the street just fine, but IMO just not worth it for their cost.
      11-26-2017, 05:59 PM   #22
tsk94
tsk94's Avatar
1522
RE71R's are very sticky for what they are (non R-compound). They are very comparable to Nittos in terms of grip. The Nittos last longer and are much better suited to longer track sessions then the Bridgestones. So it depends what you're looking for.
Hawkeye is right though, the Nittos are quite expensive compared to the Bridgestones, but they have their advantages over them also.
