05-11-2017, 09:24 PM | #1 |
12
Rep 48
Passenger Restraint Malfunction
"Fault in passenger restraint system...."
Just got this code out of nowhere. Any idea what could be wrong? I tried searching everywhere and every thread says something different. Anyone can help? |
05-11-2017, 09:40 PM | #2 |
4452
Rep 4,014
I have the same thing and at this point it has been determined that it is the seat sensor that determines if someone is sitting in the seat. But it may also be the seatbelt tensioner. I will find out for sure when she goes in for the air bag recall.
05-11-2017, 09:57 PM | #3 |
12
Rep 48
Is it safe to leave the light on?
05-11-2017, 10:08 PM | #4 |
4452
Rep 4,014
Just don't drive 60mph straight into a wall and I think you'll be fine. Eventually you should probably head to your dealer or local mechanic to have it checked out. I don't believe anyone can diagnose it remotely from here. Is it driver or passenger side?
05-11-2017, 10:33 PM | #5 |
12
Rep 48
I just hate having these lights on. Its the passenger
05-11-2017, 10:44 PM | #6 | |
4452
Rep 4,014
05-12-2017, 12:38 PM | #10 |
4452
Rep 4,014
Yes OP, this is a possibility. Access to the battery is fairly easy. To your question yes, It can be coded out if it's the seat mat sensor but you have to disconnect the sensor wire under the seat and then someone like alex@alpine can code it for you for his advertised price of $60. Or a number of independent shops in your area also I am sure. I have not checked my battery wire as my trunk is loaded right now and I was going to have my service guy check that when I go in for my air bag recall. If not sure where the battery is or which wire to jiggle just use the search tab here or google it. It will definitely come up. Keep us updated on your progress, will definitely help other members if the battery wire jiggle works.
05-12-2017, 01:04 PM | #11 |
58
Rep 383
I taped mine down over the battery with a couple layers of electrical tape. Then i bought a battery hold down arm that comes on the 3 series verts that bolts across the top of the battery. I bent the arm a little to provide more pressure down to keep the battery from moving.
05-12-2017, 01:46 PM | #13 |
4452
Rep 4,014
05-13-2017, 02:05 PM | #14 |
202
Rep 749
Drives: 335i xDrive
05-14-2017, 08:34 AM | #16 |
Save the manuals!
6019
Rep 6,750
Like I said before, SCAN IT. You need to know which exact component of the ABG system is triggering be fault. THEN you can disable it via NCS and clear the faults.
Otherwise you're just guessing with multiple possibilities and wasting your time.
'16 M3 | '23 718 Spyder Past: E92 M3, F87 M2, E39 M5, etc |
05-14-2017, 09:16 PM | #17 | |
202
Rep 749
Drives: 335i xDrive
If you need help with coding it then ask. |
05-15-2017, 11:20 AM | #18 |
12
Rep 48
05-15-2017, 12:31 PM | #19 |
4452
Rep 4,014
