05-03-2017, 04:51 PM | #1 |
Rep 2
Wheel Adapters 5x120 to 5x114.3
First post, looking for some reassurance.
Just got a 128i back in March and I have a wheel/tire combo on my previous vehicle which is a Nissan. I'm hoping I'll be able to use these adapters to put them on but I have a couple of questions. 1. Will the adapters work with the wheel bolts vs. studs/lugnuts? I've never had a vehicle that uses the bolts. 2. I've looked endlessly but can't find any adapters less than 1" thick, which worries me since the wheels are 18x8.5 +35. Anyone know of somewhere I can find the correct adapters at 1/2"? Thanks for any and all help. |
05-03-2017, 05:25 PM | #2 |
545
Rep 1,233
I'm sorry to burst your bubble, but there is no way you are going to fit an 18x8.5 ET35 wheel on an E82 with a 1" wheel adapter. You'd have trouble with the wheel alone, nevermind the adapter.
The E82 1 series is very restricted in wheel sizes that fit without fender work etc. Stock offsets are ET49 and ET52 front and rear to give you an idea. Do a bit of research here and you'll see what I'm talking about... |
05-04-2017, 03:09 AM | #3 | |
Rep 2
My setup will clear the struts and the diameter is only ~8mm more. I'm not worried about them fitting. I'm more worried about the poke (asking about 1/2" adapters) being too much and also the question about using adapters with wheel bolts. My tires are 235/40 btw... Last edited by BrooksyE82; 05-04-2017 at 03:18 AM.. |
05-04-2017, 11:07 AM | #4 | |
545
Rep 1,233
The cars just don't have much room....unfortunately. |
