03-30-2017, 03:40 PM | #1 |
17
Rep 193
Drives: 2009 Black 135i
FT: Procede Tuning Rev3 for JB4
Procede Rev3 won't work with new 335is but JB4 will? PROCEDE REV3 OFFERS Plug and Play (PnP) Harness AutoTuning Vishnu Command Center Closed-Loop Ignition Timing Control Flat-Foot Shift/No-Lift Shift (6MT) 2-Step Rev Limit/Launch Control (6MT) Built-in PWM Methanol Control I/O Built-in Methanol Pump Arming Circuit 3bar MAP sensor input External 0-5v wideband input Automatic Wastegate Compensation In-Dash Multi-Informational Displays On-the-fly Mapswitching DME code reading/clearing Built-in Wideband AFR Monitoring High-Speed Datalogging In-Dash Trouble Code Display Isolated PID Boost Control Speed Delimiter Diagnostic Invisibility Adjustable/Audible Shift Alert Diagnostic Adaptation Resets Wastegate Rattle Fix Performance Traction Control Secondary Autotuning Map (Map2) Naturally Aspirated Map (Map3) Progressive Methanol Map (Map4) Complete map-ability though User Tuning Interface USB interface (cable included) |
03-31-2017, 09:42 AM | #2 |
50
Rep 174
Nobody uses Procede anymore. Its old and outdated.
2010 BMW 135i
Alpine White, Manual Trans, Navigation, Boston Leather N54Tuning Dowpipes MMP Inlets Eisenmann Race Exhaust with mid cat delete AMS Intercooler BMS Chargepipe with dual Forge BOV Ohlins Road and Track (Vorshlag camber plates) M3 control arms Rear Subframe Bushings OCC and RB PCV |
