03-25-2017, 11:25 AM | #1 |
Tinkerer
83
Rep 532
e92 2010 rear blind retrofit
Hi all,
i've installed a rear electric rear blind this morning and followed the retrofit guide. Ive used NCSexpert to change the VO to include $415 (rear blind), the car now "knows" that it has one installed, (checked vo in ista-d, Ive reset the JBB module (via an empty MAN file). The button lights up but does not operate the blind, i've put it up manually (powered it via a light connector), so I know the blind works. Do I need to process *all** the modules for it to work? its a proper retrofit as I have the bmw install guide, so it should be possible. Do I need to use ista-p and use the retrofit options? Installed the Tv and coded and that works perfectly, again used NSCexpert to add the TV to the VO. (again its seen when the vo is read out). Will be doing the heated seats and Individual audio install as well soon. Anyone have any ideas, it would be greatly appreciated. John
2014 F25 X3 335d M-Sport:
03-29-2017, 03:45 PM | #2 |
11
Rep 95
You need a new JBE. I searched high and low and was pulling my hair out on this retrofit as well. I was only able to get it to work with a new JBE.
PM me. I will give you the email of whom I got the new JBE from Last edited by hththt; 03-29-2017 at 03:52 PM.. |
03-30-2017, 11:11 AM | #3 |
750
Rep 4,429
I'm having the same issue!
ModeCarbon V1 CF lip/PF AG CF SS ext./ARKYM CF Diffuser/OSS AE's/B&G Springs/CF Performance Spoiler/V2 Led Performance SW/Meisterschaft GT exhaust
04-01-2017, 12:35 AM | #4 |
Lord Scrip
1819
Rep 3,015
Drives: 2011 M3 Coupe
You should PM OP your MAN file so he can try it. NCSExpert will not use it if it's wrong. I think it's a coding issue guys.
05-15-2017, 08:10 AM | #6 |
BimmerPost Supporting Vendor
3752
Rep 2,907
Drives: 2011 E93 M3
Curious.... ANy explanation as to why a new JBE was required?
05-15-2017, 08:25 AM | #7 |
Tinkerer
83
Rep 532
The blind needs and extra set of relays in the jbbr to trigger/power the blind motor.
I suspect that a convertible jbbr will also work (as it has the extras), but I bought an M version of the JBBR and once coded to the car (with my dump), it worked straight away.
05-15-2017, 09:06 AM | #8 |
3752
Rep 2,907
Drives: 2011 E93 M3
I assume when you say JBBR(?) you mean JBE. (Junctionbox Elektronik)
It is curious as BMW (realoem) doesn't identify any differences in the Junction Box 3 electronics and lists the same # JBE for all 3 series including the E93 (and Z4, X1, E81 also). I can confirm this as well in the cars I have dismantled. They all have the same JBE module- coupes, convertibles, and even coupes with the rear shade. So on the surface there appears to be nothing unique to the H3 modules. The pre-LCI modules (H1) I would definitely imagine there being differences... I wonder if there is maybe the off chance that something was damaged in your old module... |
05-15-2017, 09:51 AM | #9 | |||||
Tinkerer
83
Rep 532
If you dismantle, selling the jbbr with the blind would be the best option as it will work. Quote:
The M version has all relays populated. I suspect that an H3 unit (lci vert), has the right amount, as its a config option for either lockable glovebox OR rear blind.
05-15-2017, 10:15 AM | #10 | |
3752
Rep 2,907
Drives: 2011 E93 M3
Just contributing my experiences. I didn't have to replace the JBE when I did a retrofit. The coupe's original H3 JBE accepted it just fine. |
05-15-2017, 10:19 AM | #11 | |
Tinkerer
83
Rep 532
Wish I'd known you were a dismaler when I got mine!!!
05-22-2017, 06:13 AM | #12 | |
Rep 26
does the Install guide mention the software update?
BMW E36 1996 118i
BMW E46 2002 118i BMW E92 2007 325i <- |
