03-17-2017, 09:06 AM | #1 |
164
Rep 258
Coding F82 GTS Rear Lights
Hi,
What's has to be coded to activate the BMW M4 GTS Rear Lights on a BMW M4 F82? Can this be done with esys? Do i need to add any VO code? Thank you! |
03-23-2017, 01:27 PM | #8 | |
56
Rep 104
Change that in your FA, be sure E-Sys isn't set to write it back to your VCM, and then VO-code the appropriate module(s), which I'd imagine would be REM. Nothing you need to know other than Typeschlussel. |
03-23-2017, 02:04 PM | #10 | |
56
Rep 104
If OEM lights had an option code, then there'd be some removal necessary. Since taillights are, from what I understand, based only on zeitkriterium (possibly) and typeschlussel (definitely), oh, and chassis code (kinda), then in this case, no, there's no removal of anything necessary. Good luck! I'll have my hands on a GTS for the first time (hopefully) sometime this week, and might be able to grab some FDL code captures for you if absolutely necessary. (I'd wager it's not.) |
03-23-2017, 02:08 PM | #11 |
164
Rep 258
To be sure: vo coding is like changing a normal transmission to a sport transmission? Edit the FA and add the VO code to the list and code the modules, right?
Like this: http://www.bmwesys.com/guides/VO%20C...ep%20Guide.pdf Nice! Looking forward to hear more! Thank you for the help! |
03-23-2017, 03:27 PM | #12 | |
56
Rep 104
In your case, I'd imagine REM would need to be involved, potentially also FEM_BODY, but with that said, I've read elsewhere that GTS taillights are plug-and-play (although I have no first-hand experience to say whether that's true), so there's a chance that the modules just need to be 'taught' in ISTA aka Rheingold... so tbh that's where I'd start first, personally. |
03-30-2017, 04:28 AM | #14 |
164
Rep 258
03-30-2017, 09:00 AM | #15 |
StigJr
8
Rep 17
03-30-2017, 06:45 PM | #16 |
56
Rep 104
Again, why don't you just VO code them with a modified FA for the GTS?
While this may seem like a pedantic response, it's simply a plea to consider the far simpler approach. |
03-30-2017, 10:36 PM | #17 |
Rep 15
Its very very expensive
2015 F82 M4 DCT
03-30-2017, 10:37 PM | #18 |
Rep 15
i dont think vin gonna help.
2015 F82 M4 DCT
02-18-2024, 11:43 AM | #19 |
89
Rep 670
[/url]
I just got my set of OEM GTS OLED's and I have a 19' LCI, I just need some help with properly coding these? Can anyone help with the assist? or Can I do this through Bimmercode myself? or Is there someone you can recommend to help me do this? Thank you! |
04-08-2024, 12:19 PM | #20 |
Rep 19
Ever find out info about coding? Have a friend who is in the same boat and trying to see if I can code it for him with Carly or Bimmercode.
Thanks! |
bertocolon89.00 |
04-08-2024, 11:26 PM | #21 |
133
Rep 265
You can’t code them in with Carly or Bimmercode as you need esys to do this. This is only really if you want the start up animation. Else will work just fine if you have LCI lights on the car already. Note you need to install the correct wiring harness as well if you want the start up animation as well.
bertocolon89.00 |
Tags |
coding, f82, gts, lights, oled |
