New 2009 2010 BMW Z4 - ZPOST
Go Back   New 2009 2010 BMW Z4 - ZPOST > BMW Z4 Forum (E89) > 2009-Current Z4 Forum (E89) General Discussion
      02-20-2017, 04:09 PM   #1
paris1
90
Drives: 2013 35i Space Grey over Coral
Coolant level ligh keeps coming on after flushing system.
My dealer recently flushed and refilled the cooling system in the course of repairing a leaking gasket. Ever since I keep getting a recurring coolant level light on the dash in spite of the fact that the expansion tank is full. Is this caused by an air pocket in the system and, if so, what's the best way to work it out? Haven't had a chance to return it to the dealer yet.
      02-20-2017, 08:16 PM   #2
jparnes1
jparnes1's Avatar
245
Drives: 2016 340i, 2012 Z4 35i
To bleed the system, do this:
Hook up a battery charger, if you have one.
Verify the level of coolant in the tank. If you have air in the system, the level will go down after bleeding.
Turn the heat to high and the fan to low
Insert the key and turn it so all the idiot lights come on, but do not start the engine.
Fully depress the gas pedal for about 10 seconds. This activates the pump and starts the bleeding cycle. You will hear the pump running on and off. Do not turn the key until the cycle is complete. This process takes about 12 minutes.
Add coolant as necessary. You should only fill the expansion tank to the minimum line. Coolant expands when hot and there needs to be room for this in the tank. Otherwise the plastic tank can develop a crack.
2016 340i XDrive, EBII/black, 6 MT, M Sport, Track Handling, Cold Weather, Tech, Lighting, Driver Assistance Plus.
2012 Z4 35i, ED 2/24/2012, Melbourne Red Metallic, Black Leather, Carbon Trim, 6MT, M Sport, CW, PP, PS, NAV, CA.
      02-21-2017, 08:50 AM   #3
paris1
90
So is this a procedure that can be performed with the engine cold or hot? What is the purpose of using a battery charger? Also, I would think the expansion tank would have a pressure relief feature to avoid damage.
      02-21-2017, 09:16 AM   #4
jparnes1
jparnes1's Avatar
245
You want to do it cold so you can remove the expansion tank cap safely. The battery charger is used so that you don't drain the battery during the bleeding procedure. You don't have to use it but why not?
And yes, you would think that would be a design feature.
      02-21-2017, 09:35 AM   #5
paris1
90
Do you leave the cap off during the procedure?
      02-21-2017, 10:35 AM   #6
jparnes1
jparnes1's Avatar
245
Yes that way you can check the coolant level and add if necessary during the bleeding cycle. Just keep an eye on the float.
      02-21-2017, 12:12 PM   #7
rking117
Drives: Z4 3.0i & 320i
if the light came on after it was flushed at the dealer then the best option is to have them fix it. I suspect that since they flushed it they will perform this at no charge. Just make sure you ask them first.
Enjoying an E89 Z4, F30 320i and Fiat Abarth //
E85 Z4 (sold), E82 128i (sold), Fiat Pop 500 (sold)
zpost
