New 2009 2010 BMW Z4 - ZPOST
Go Back   New 2009 2010 BMW Z4 - ZPOST > BMW Z4 Forum (E89) > Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications
      02-08-2017, 03:09 AM   #1
penguen
Turkey
Drives: F30 320d luxury
Any x pipe or h pipe on stock exhaust?
Hi there, as i mentioned in subject do we have any )
I have a custom exhaust with x pipe but even i m fully cattles, it killed my exhaust burble significantly. I considering removing x pipe and using h pipe or just true straight dual exhaust.
I need to decide it in 4 hours, any fast replies are welcomed
Thanks for reading.
Note: I will make before after video.
      02-08-2017, 12:47 PM   #2
jts1981
jts1981's Avatar
213
Drives: n54
Hmm, the 35is has a small xpipe stock. Do you change the pipe diameter? What mufflers did you go with?
      02-10-2017, 03:23 PM   #3
fmorelli
fmorelli's Avatar
Drives: Atacama Yellow 35i
I have h-pipe, catless DP, 49-state high flow cats in the mid-pipes, h-pipe after those cats. Burbles just fine (and tune seems to matter on that). System is full 2 1/2" dual.
Filippo
2011 35i MT Atacama ... lots of bits. Full Öhlins TTX custom suspension. Build thread.
Build sheet. Currently finishing suspension, fuel, ignition system with Barry Battle @ 3DMMotorsport.
      03-07-2017, 09:31 PM   #4
ttuner
ttuner's Avatar
68
Drives: z4
i used an x-pipe from supersprint.
it had to be modified to fit my remus axel back, but the combo sounds great. not too loud or ricey.
2011 BMW Z4 35i | FBO | VTT Stg 2+ (EK, 20T clipped)| Motiv PI| Motiv Tuned | Fuel-IT Stg 2 + inline fuel pump | Spec Stg 3+ clutch | MFactory flywheel | 606whp 575Lbs |
zpost
